Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 09-29-2012, 01:23 PM
dscharoun dscharoun is offline
Vehicle: 2003 Dodge Ram 2500
Trim Level: Standard
dscharoun is on a distinguished road
Default Radio and Cigar Lighter Stopped Working
I recently purchased a 2003 Dodge Ram 2500. The radio did not work when I drove the truck home from the seller, and the cigar lighter stopped working about an hour later. I have checked all of the fuses and all test ok, and when I measured the voltage at the wiring harness for both the radio and lighter, both read approximately 4volts, instead of 12 or 13.8 volts. I tested the grounds on both harnesses and they appear to be good as well. Anyone have any ideas on how to repair this? Thanks.
Old 09-29-2012, 06:10 PM
moparornocar72's Avatar
Rep:630
Make sure they didnt tap power from somewhere else for the radio if it is aftermarket.
14.268 @ 95 MPH Full Trim
Old 09-29-2012, 10:53 PM
Default ProblemPr
I'm sorry, I should have mentioned the vehicle has a factory installed radio, not aftermarket. However, based upon some hand written numbers on the radio (I removed the old and substituted another used factory radio) it appears the factory radio is not the original.
