Old 09-30-2012, 09:27 PM
el diablo en fuego's Avatar
el diablo en fuego el diablo en fuego is offline
Vehicle: 2007 Dodge Ram 1500 MegaCab
el diablo en fuego is on a distinguished road
Angry '07 SLT Mega Cab A/C just quit....
Any advice? Nuthing except the A/C light comes on. Even with the A/C button off, the blower doesn't blow at any of the fan speed settings. Help!
Old 10-01-2012, 12:00 PM
Rep:1915
The most likely culprit is the blower motor resistor. Use a test light to test for power on the pk/lg wire with the ignition in the run position. If the test light burns brightly, you most likely have a bad resistor. Less likely is a blower motor failure. Make sure to check the connection to the resistor as it may be melted.
