Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 09-30-2012, 12:07 AM
powerwagon powerwagon is offline
Vehicle: 2011 Dodge Ram 2500
Trim Level: ST Reg. cab 4X4
Color: Bright Red
powerwagon is on a distinguished road
Smile Need softer front springs --Help!
My 2011 Ram 2500 has the heavy duty snow plow prep package and the front springs are too stiff for me. I don't intend to install a snow plow and want to change the front coil springs to get a softer ride. I want to keep the same height that I have now. Where can I buy coil springs that will not change the height of my truck but are a bit softer? All of the aftermarket springs I have found are made to lift or lower a truck. Progressive springs would be great. I would rather not go to my Dodge dealer for springs if I don't have to.
Thanks in advance!
'Powerwagon'
Old 09-30-2012, 02:55 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Thanks in advance!
'Powerwagon'
They will soften up with time don't worry about that, if you try driving on very very rough surfaces that are very bumpy (keeping in mind the tires wear faster) this will help soften them a bit. Personally it's not worth the time money or sweat to change springs just because the ride isn't soft enough BUT again that is my personal opinion, truly I think stiffer springs are better because what happens when the vehicle ages with soft springs, they will effect the handling and safety of the vehicle not to mention that you would then be required to replace the springs. So stiff springs last longer and again they will soften up and you will get use to the ride, give it some time. Only thing about stiff springs in the front is the tendency for oversteer but I know dodge has revamped there front stabilizer bar since the old 1990's era, thank god.
Anyways just my 2cents and hope everything works out better for you.
Old 09-30-2012, 03:22 AM
ray5.9rt ray5.9rt is offline
Vehicle: 2005 dodge ram 1500 4x4
Color: LT BLUE
ray5.9rt is on a distinguished road
you can also try taking some air out of the front tires i would say not to go below 50psi fronts and unloaded you can go down to 45 psi in the rears...
