Old 09-29-2012, 11:14 PM
powerwagon powerwagon is offline
Vehicle: 2011 Dodge Ram 2500
Trim Level: ST Reg. cab 4X4
Color: Bright Red
powerwagon is on a distinguished road
Smile My 2011 Ram 2500 rides rough
My 2011 Ram 2500 has the heavy duty snow plow prep package and the front springs are too stiff for me. I don't intend to install a snow plow and want to change the front coil springs to get a softer ride. I want to keep the same height that I have now. Where can I buy coil springs that will not change the height of my truck but are a bit softer? All of the aftermarket springs I have found are made to lift or lower a truck. Progressive springs would be great. I would rather not go to my Dodge dealer for springs if I don't have to.
By the way,I love my truck!
Thanks in advance!
'Powerwagon'
Old 09-30-2012, 08:38 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Have you considered going the bag route?
I believe that Army of One is a TLC vendor.. you might wish to look him up for more info
good luck
Exco
Bill
Old 10-01-2012, 12:42 AM
Color: Bright Red
What is the bag route?
Thanks,
Powerwagon
Old 10-01-2012, 04:16 AM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
You need to go to a good shop that does spring work
maybe this one, or not, you won't know until you call them
Wheeling Spring Service & Truck Parts
2301 Main Street
Wheeling, WV 26003-2813
http://www.wheelingspring.com/Truck_...eeling_WV.html
Old 10-01-2012, 11:32 AM
svt2026 svt2026 is offline
svt2026 is on a distinguished road
You should have got a 1500 for comfortable ride. You will not get one from a 2500. Springs are stiff and the tires are at 60psi range.
Old 10-01-2012, 06:56 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
TLC will likely not do what you are attempting to accomplish as you are trying to alter the front coils for ride comfort.
There are companies out there who will sell you springs with lower spring rates which will result in a less heavy duty ride up front. Mostly this is for people who long-haul large gooseneck RV's and need a 3/4 ton or 1-ton truck to do it, but dont want the solid axle bouncy ride that comes with it.
Another thing you can do is simply buy a 2wd model. They dont ride as rough. I know that is an expensive proposition so look around local to you at a spring shop and maybe google can yield some interesting stuff.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 10-01-2012, 10:13 PM
Color: Bright Red
My company truck is a Dodge 2500 and does not ride bad at all. I have put over 100,000 miles on it and I like it. Thats why I bought a 2500 for my personal truck. I need the 3/4 ton for my slide in camper but don't need those extra stiff front coils that the snow plow package gives it. I wonder if anybody who has removed standard coils for a lift would want to sell them?
I will check out the spring place in Wheeling WV. Thanks!
Old 10-04-2012, 06:59 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
I would highly recommend installing the KORE leveling kit. The springs it comes with along with Bilsteins totally changed the ride in a good way.
Old 10-04-2012, 09:49 AM
whatroads whatroads is offline
Vehicle: 2011 Ram 1500 4x4
Trim Level: SLT 4x4
whatroads is on a distinguished road
I had a 2005 QC 3/4 4x4 HD. I found the ride better when I filled the bed with firewood. Any weight would do. 4-600 lbs seams to do the trick
Old 10-05-2012, 01:33 AM
Bikenut's Avatar
Rep:73
Thats a good point. Bottom line is that it is made specifically to haul/tow so throwing some sand bags in the bed or whatever weight makes it ride MUCH nicer. If you do that all the time though, it will affect mileage and brakes and some general wear and tear I would assume
