Water leaking???? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 10-01-2012, 08:25 AM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
Default Water leaking????
Hi gang, noticed the last few days I have had water leaking from my truck. Now all my fluids are fine and I have had condensation on the truck in the mornings. After a 17 min ride to work and 1 hour sitting I keep getting this big puddle under the truck. Is this a common thing or do I possibly have something wrong? It's alway in the same spot.
And like I said dew on the truck in the mornings and in the 50's so it's not air conditioning runoff
Old 10-01-2012, 08:40 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Looks to me like the condensation from the air conditioner. Try driving without the AC on and see if it still happens.
Sean
Old 10-01-2012, 08:49 AM
Vehicle: 2009
Rep:68
Airs not on , but the heater is on full most of the ride. 6 other cars in the parking lot including a 04 ram and mines the only one that does this. I find it hard to believe that that much dew water could build up and drain from the same spot. If so then that really scares me as far as what the backside of my sheet metal looks...
Old 10-01-2012, 08:51 AM
snrusnak's Avatar
Rep:1388
What about defrost? If defrost is on then the AC compressor is on.
Otherwise I'm not really sure... If the heater is on then it's cold out...right? Do you possibly have ice forming in the cowl and then the heat is melting it?
Sean
Old 10-01-2012, 09:06 AM
Vehicle: 2009
Rep:68
That I did not know! Yes the defrost was on for half the ride in. Thanks for the info ! I will make the ride in tomarrow without the defrost on . Didn't really need it on to see......
Old 10-01-2012, 07:58 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
you hit the nail on the head here...guaranteed this is your issue.
