Old 10-01-2012, 01:14 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
Post Replaced RES radio to Mygig 430, version difference?
I purchased a 430 mygig on ebay that claimed it was from a 2011 Ram 1500.
It works as expected but the splash screen comes up at Chrysler. I updated the firmware from 8.03.02 to 10.00.11. Noticed the splash screen changed from the large uconnect logo and small chrysler logo to a big new chrysler logo and a small uconnect logo. Functionality is the same, a bit speedier.
The radio now has a VID tab, nothing happens when pressed.
This is the same functions as my first RBK radio in my charger, but when the radio in the charger was not working right, it was replaced with a new RBK but that unit now had pause/rewind satellite, sports update, favorite artist notifications etc... I know that Mitsubishi made one version (or series of the mygigs) and Harmon-Becker made another.
Does anyone know on what year or date code things changed?
My mygig info. model P05064678AH A
supplier: 42774
date code 1640
I found myself on the mygig forum (http://mofv.com/mygig/BBS/index.php)
and I tried all the suggestions to get the Dodge logo to appear. any ideas?
Ok, I just spoke with Mike and Steve over Radios and More dot com and Steve (the chrysler tech) told me that in 2011-12 the radios were made by another supplier and that the tagging of songs/artist and satellite pause/rewind is a function in 2011-12 radios.
Old 10-01-2012, 05:28 PM
Rep:2657
Hopefully XSDBS sees this post, he seems to have more information than most members
do you have the
430N RHB or the 430 RBZ
a site that seems to have a lot of info is below, they are a sales site, but they cover each of the radios in detail
http://www.oemautopartsco.com/index....NA)%22&sort=3d
Old 10-01-2012, 05:33 PM
Rep:126
I have the 430 RBZ
Old 10-01-2012, 06:37 PM
Rep:2657
You can see how XSDBS tries to help people
These are questions that he tries to answer on the RBZ
it is a long post, several pages
http://www.ramforumz.com/showthread.php?t=108564
Old 10-02-2012, 09:02 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Hello GTyankee,
How are doing today? Great I hope.
On this question I have a couple of thoughts about it and I have sent a friend an email to verify them.
1) I believe that the radio that Socalgordon has purchased is a 2009 -2010 RBZ radio out of a T&C vehicle.
2) The VID tab that he's getting now may be for rear seat entertainment and probably wasn't an option with the earlier SW version.
3) I'm pretty sure that if you change out a base radio to a touchscreen radio, the TPIM should (doesn't have to be in order for it to work) be flashed to remove the base radio and add the new touchscreen radio to the vehicle build. Once this is done the TPIM send a CAN BUS message on the vehicle type which then lets the radio display the correct logo.
I have also heard that the logo information is stored in the PCM.
I'll get back to this thread when I get the email back.
Old 10-02-2012, 09:26 AM
Rep:2657
could it be that the VID button is really VES ??
Old 10-02-2012, 01:14 PM
Rep:126
Exclamation
I believe it is from a 2010 vehicle, judging from the date code of 1640
the first 3 of the code, 164, is the days of the year it was built, June 13th, the last number signifies the year, 0 = 2010.
Unless the radio was made and put in an early build of a 2011?
Old 10-03-2012, 07:26 AM
Rep:73
FYI, I'm still waiting on a reply to verify the programming but I am pretty sure that the dealer has to delete the factory radio and add the new radio to the vehicle build.
Old 10-03-2012, 12:51 PM
Rep:126
Another interesting piece of oddity, I have imported some pictures, selected them to be default but they do not show up when you look at the main screen. It is selected as the default pic, I even tried selecting the default beach pic and that does not even show up. The damn Chrysler logo shows up. grrrr.
Question, If I get a 730 mygig, do those come with bluetooth and uconnect built in and I would NOT have to get the extra add on devices? I would just need the microphone cable, correct?
Old 10-03-2012, 03:03 PM
Rep:2657
When you have time, take the 2 or 3 screws out on the dash bezel & get it out of the way enough to get at the new radio. Then pull the 4 screws out of the radio mount.
Pull the radio out enough to see the label on top of the radio, if you can, take a picture & post it. It has all the info needed on that label.
http://www.youtube.com/watch?feature...a4pFjZSts&NR=1
Useless infomation
the radios RHR & RER 730N, as you know are navigation radios & they use the NAVTEQ mapping
the RHB 430N, is also a Navigation radio, but with the better Garmin mapping
If i were in your position, i would be on the telephone, talking to Al & Ed's Autosound, asking about getting this installed, there are at least 3 locations near you. Corona, Riverside, & Ontario
http://www.al-eds.com/Parrot-P1020005AE-p24761.html
http://www.crutchfield.com/p_333CK31...k.html?tp=8395
It is a hands free bluetooth car kit, it comes with wiring kit, the brain (module), a microphone, & a very small dash unit. It uses your own Ram speakers, just like the Uconnect module does. The microphone can be placed anywhere that you want it, on my last vehicle it was on the overhead console, between my head & the mirror, worked perfectly.
I believe that you would only need a $40 or less RBZ radio antenna
