Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 10-01-2012, 03:12 PM
Coastiejoe's Avatar
Coastiejoe Coastiejoe is offline
Vehicle: '11 Ram 1500
Color: Silver/Gray
Rep:37
Coastiejoe is on a distinguished road
Default 2WD Front Shock Question
Hey all,
Im planning on replacing the front shocks on my 2wd 99 1500. The only concern I have is the lower shock bolts. My truck is very rusty and I dont know if I will be able to salvage the old bolts as they will probably need to be cut off. Does anyone know what kind of bolts are used or have a link to a place that sells them?
Thanks.
Old 10-01-2012, 03:42 PM
Rep:2705
go to the auto parts or a home improvement store & buy some PB BLASTER
forget WD-40 & Liquid Wrench
There is only one product that is available locally & works better then PB Blaster is a product called KROIL, it can be purchased at Gun Shops & is more expensive
Give your bolts a good shot of PB BLASTER & go do something else for a while, like look for the tools to take the bolts off
If it doesn't seem to work, use a small bottle of MAPP gas to heat up the nut
If you decide to replace the bolts & nuts, go to a place like a Home Improvement store or NAPA & purchase a GRADE 5 bolt & nut, grade 3 may work, grade 8 would be overkill
check the thread count on the new hardware, fine or course thread, metric or standard
Old 07-12-2013, 10:00 PM
kylegritt2012 kylegritt2012 is offline
Vehicle: 1999 dodge ram 1500
Rep:12
kylegritt2012 is on a distinguished road
I did this to my 99 2wd a couple years ago. I had to grind off most of the bolts all the way around. I just used some galvanized bolts I had in the garage to put the new shocks on. You don't need to try and save the old bolts. They are junk anyway.
Old 07-20-2013, 03:08 AM
jabba974 jabba974 is offline
Vehicle: 1997 Dodge Ram 2500
Color: Driftwood Satin Metallic
jabba974 is on a distinguished road
Pb blaster or a torch should work....Use new bolts anyway..
