Old 10-01-2012, 05:01 PM
Talltwisted1
Default 5.9 wont Idle or accelerate
Swapped in a 360 in place of a 318 in a 99 1500 4x4 sport tried the computer that came with a 109k 360 tried the original computer same issue upon cold start up will idle fine but wont accelerate past 1800 rpm without popping and farting and backfiring after idling for 15 minutes, starts to increasingly misfire and pop idle and acceleration completely turns to crap new crankshaft and cam position sensor tried shutting down and resatrting runs badly until it completely cools down
Old 10-02-2012, 09:59 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Fuel pressure? sure sounds like it.
Old 10-02-2012, 08:12 PM
zachcroft zachcroft is offline
Vehicle: 1996 dodge ram
Color: green
zachcroft is on a distinguished road
sounds like your not getting proper fuel. if i was you i would see if the fuel pump is pumping enough gas. you might have to get a fuel pump for a 360. the original fuel pump that was fueling your 318 may not be able to satisfy the thirst of the 360.
Old 10-04-2012, 12:57 PM
Talltwisted1
thank you guys i checked the fuel pressure and it is at 40 psi not sure what the standard range is im going to look for that now
Old 10-04-2012, 01:26 PM
Rep:1890
What about feul flow? Volume is equally as important as pressure.
Old 10-04-2012, 01:28 PM
Colorado700R's Avatar
Colorado700R Colorado700R is offline
Vehicle: 2011 Ram 1500 Crew 4x4(Rambox)
Rep:34
Colorado700R is on a distinguished road
puddling fuel injectors....
Old 10-04-2012, 09:37 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Look down thru the throttle body. Is the inside floor of the intake manifold oily? Thinking you have a very badly blown intake plenum gasket.
Old 10-05-2012, 12:50 PM
Talltwisted1
ok looked at the inside of the intake not oily not dry but no visible oil looks like some wetness but not sure if that would be an all the time thing or only when hot putting the exhaust back together with a different cat and hoping that might make some change when i clear the ecu and let it sit for awhile it runs and revs awesome but as it heats up i hear the periodic misfire and it takes about 3 minutes once that starts to happen for it to nosedive into constant miss and sputter with almost no idle quality
Old 10-05-2012, 12:51 PM
Talltwisted1
By the way thank you to everyone that offered advice This is my first Dodge project. Im gonna name this truck Christine I think Shes possessed.
Old 10-05-2012, 12:57 PM
Rep:1890
The fact that it only does it when it's hot makes me think maybe the ignition coil is getting hot and breaking down. Also double check your ground wire connections.
