3.7L torque converter in a 4.7L? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 10-02-2012, 09:29 AM
speedplayer speedplayer is offline
Vehicle: 2003 dodge ram
Rep:30
speedplayer is on a distinguished road
i know the 3.7 and 4.7 have different part #s.Our 4.7s put out more power then 3.7s do, that will make the TC stall a lil higher for us. i have 70mm TB, HO cams, 4.56 gears, electric fan, underdrive pulley, i tune my own truck via SCT. i will try this mod in few weeks from now, i will report back when iam done.
Old 10-02-2012, 09:31 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yeah please post back, I'm interested in the results.
BTW how do you like the 4.56's in you truck? Can you comment on mpg on the highway?
Sean
Old 10-02-2012, 09:43 AM
Rep:30
YEAH i will post when i get this mod done, it will be a cheap mod for all of us if it works. 4.56 gears are great. quick lounch and better mpgs. the draw back of goin that tall of a gear is that theirs no downshift on freeway speeds.
Old 10-02-2012, 09:55 AM
snrusnak's Avatar
Rep:1388
I have 3.55's and when in 5th gear(first overdrive) it puts me at nearly the same rpm as if I were to have 4.10's and be in 6th(second overdrive) and I basically get identical mpg at 70mph. As long as I'm on flat ground, cruising anyway. And I like how much more responsive it feels. I'm just worried going to 4.56 will lose me some mpg.
What mpg do you get on the highway? With the 3.55's I have gotten as high as 22 and 23mpg on long trips. I'd expect with 4.10's to still be able to get 20 mpg easily. I know the older 4.7L isn't as good on gas too though, my dad's 05 only gets ~17mpg hwy with 3.55's.
I am thinking of doing 4.10's and if I want more to drop my tire size an inch and that'd be like doing 4.20-4.30's with stock size tires. Sort of in between.
Sean
Old 10-02-2012, 10:03 AM
Rep:30
I dont know the final overdrive ratio on your transmission, but on the 545rfe their pretty high. we can used 4.56 gears and at 65mph and see 2000-2100 rpm. with 4.56 gears i recommend cam or something, it will feel sloppy due to not enough power. you want to go with 4.10 gears? go for it, that will help out your 08. i can see your truck in the high 14s. oh mpgs were about the same if not 1-2mpg improvement
Old 10-02-2012, 10:09 AM
snrusnak's Avatar
Rep:1388
Our trucks have the same 545rfe. I actually have a 2010. 5th is 0.75:1 and 6th is 0.67:1.
I figured with 4.10's and 31" tires 2100 rpm at 70mph
I figured with 4.56's and 31" tires 2300 rpm at 70mph
Not a huge difference but am still worried about the mpg.
With my 3.55's and 31" tires I'm at 1,800 rpm at 70mph.
My truck(quad cab) runs ~16.0 now with drop in filter and SC 93 tune. I also have really heavy aftermarket wheels and tires.
I'm not really looking for fastest 1/4 mile time, just want a nice truck to drive on the street. A lot of people say they get good mpg with the 4.56's but I've never seen anyone claim a number, like say 20mpg with 4.56 at 70mph. I can get 20+mpg now even at 75-80mph and don't mind giving some up but not too much. I rarely drive highway, but once or twice a year we drive half way across the country so it is still somewhat important to me...
I'm planning on a ram air to feed the stock air box, maybe headers if ever available or if I ever attempt to make my own, maggy y pipe and a muffler, and that's about it. I'd probably get cams if they were available and if I needed to pull the top end apart for other reasons...
Sean
Old 10-02-2012, 01:05 PM
Resident Technician
Rep:1915
This is because the 42RLE is used behind the 3.7 in the Ram. Are you sure the splines will match up with a 545RFE?
Old 10-02-2012, 01:09 PM
snrusnak's Avatar
Rep:1388
What about in the jeep liberty? That's where he's getting it from...
Sean
Old 10-02-2012, 01:25 PM
Resident Technician
Rep:1915
Maybe from an older diesel Liberty, but I can't ever recall seeing a 545RFE behind a 3.7.
Old 10-02-2012, 01:27 PM
snrusnak's Avatar
Rep:1388
Ok now I'm really confused lol. Earlier today you posted:
The 3.7 can use the 545RFE or the 42RLE transmission
Sean
