Dodge Ram Decals
Old 10-02-2012, 07:23 PM
eLeppert's Avatar
eLeppert eLeppert is offline
Vehicle: 2006 Dodge Ram 1500
eLeppert is on a distinguished road
Default started revving high randomly
so i was on my way home from work when i noticed my engine was revving high, engine fan was goin crazy, and the rpms would rise everytime i pushed the clutch in to shift. it idles at a normal rpm, around 600-700, so i dont think its the IAC valve. took a look at the intake and throttle, all looks clean and normal. I just cant figure out what it might be. any ideas?
Old 10-03-2012, 03:05 PM
welshdog welshdog is offline
Vehicle: 2005 Dodge Ram 1500
welshdog is on a distinguished road
Smile high revving.....
Hi there, reading about your problem, have you thought it might be the throttle position sensor? I had this problem some time ago and replacing this part cured it. It is not expensive and only takes 5 minutes to do. Remove two screws and disconnect the electrical supply. Hope this works for you!
Old 10-03-2012, 03:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Any check engine lights?
How many miles?
So it idles normal but when you press the clutch in the rpms go crazy? A little more info, specifics, would help. Sounds like a faulty sensor or vacuum leak.
Sean
Old 10-06-2012, 12:08 AM
eLeppert's Avatar
no check engine lights, i've got 94,949 miles on the truck. it idles normal but seems to run fast when in gear and rpms shoot up when i step on the clutch to shift. it also sounds like my engine fan is goin pretty nuts but the engine temp is normal
Old 10-06-2012, 12:10 AM
snrusnak's Avatar
Rep:1388
I'd guess either a vacuum leak or fuel pressure issue(too much).
Sean
