Place your Ad Here!
Old 10-03-2012, 12:39 PM
Saddlehorse Saddlehorse is offline
Vehicle: 2008 Ram 1500 5.7
Color: Champagne
Saddlehorse is on a distinguished road
Question Gas guzzling idler
My 2002 ram 4.7 sitting at an idle uses about a gallon of gas every 10 minutes or less.
What would cause this? Not leaking and not idling high.
Thanks
Old 10-03-2012, 12:46 PM
Resident Technician
Rep:1915
If it's burning all this fuel, you should have a MIL on and codes for a rich exhaust and standing anywhere near the truck would burn your eyes out. In fact, it's a bit difficult to imagine how it's not flooding and killing itself.
Old 10-03-2012, 12:53 PM
Color: Champagne
That is part I don't get. No smell no codes no gas out exhaust pipes. Or anything.
Just a puff of smoke after a few minute idle then take off or accelerate.
But figured smoke was from oil seeing how intake is full of it.
Old 10-03-2012, 01:22 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
There is no way that thing would run using that much gas at idle. How are you figuring out what it's using? The display? I would suspect THAT first.
Old 10-03-2012, 01:29 PM
Color: Champagne
At first I thought it was a problem with display. But had that and electrical checked.
I can't figure out what is going on with it. All I know is thistruck is the biggest pile of crap.
Between that and the oil in intake and whatever causing that.
Old 10-03-2012, 01:38 PM
Resident Technician
Rep:1915
The oil in the intake is caused by a blown plenum pan gasket, which happens to all of these engines. This can also result in increased oil consumption and spark knock but I've never known it to cause a fuel consumption issue.
Old 10-03-2012, 02:03 PM
Color: Champagne
Had the oil problem on my 5.2 . Was wandering if it was same issue on the 4.7
Guess I wil have electrical checked again cause that is only thing that makes sense.
thanks
Old 10-03-2012, 02:10 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
There's no way it's using that much fuel, it wouldn't run.
Sean
