Old 10-03-2012, 04:23 PM
dgreen3855 dgreen3855 is offline
dgreen3855 is on a distinguished road
Default Tire Pressure Monitoring System TPMS
I was wondering if there is a way to recalibrate our TPMS. For example mine says I have 30 PSI on a certain tire and every external gauge I use shows I have 34-38(obviously I have tested a few). I know it may seem miniscule but I really would like for it to be accurate or at least closer. Any help would be greatly appreciated.
Old 10-03-2012, 05:54 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
are you taking your mesurement when your tire are cold or just after you went for a drive??
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 10-03-2012, 06:11 PM
I have done both. They seem to be consistently off by about 4 PSI.
Old 10-03-2012, 06:17 PM
Rep:2616
Do you have a Discount or American Tire store in your area
they have the same TPMS remote reader that the dealerships use, it is just in a different outer case
Most large Chain type tires stores likely have the same tool
The tool is used for checking & setting the wireless set up used in TPMS systems
http://www.bartecusa.com/
https://millerspecialtools.spx.com/Detail.aspx?id=1643
Old 10-03-2012, 06:28 PM
Biggesthorn's Avatar
Biggesthorn Biggesthorn is offline
Vehicle: 2009 dodge ram
Trim Level: Bighorn
Rep:14
Biggesthorn is on a distinguished road
sounds like a faulty sensor (assuming you havnt used runflat) that stuff can show lower readings or clog sensors up completely
ive seen them come in and have to be reset because because of different reasons but never because there only "somewhat working"
5" lift 35" mud grapplers 20x12 fuel hostages rbp grille rbp steps nfab front and rearrunners
Old 10-03-2012, 06:50 PM
I do have discount tire in the area I can take it to. I have never used the Fix a Flat stuff you are talking about. Are you saying I can go to Discount Tire and since they have the same system they can test and recalibrate my system if needed?
Old 10-03-2012, 07:04 PM
Rep:2616
They did for mine & then did it again when i had changed to aftermarket rims
