Old 10-03-2012, 03:23 PM
badjuju2010 badjuju2010 is offline
Trim Level: Sport 4x4
badjuju2010 is on a distinguished road
Default Help Needed on Lift Setup
OK, I know im going to get fussed at for starting a thread on a topic already covered but i have read so many different ideas i have tunnel vision. I just bought a 2010 Ram 1500 4x4 Sport and I am ready to pull the trigger on a lift and tires but need help on which lift to go with, wheel spacers or not, coil spacers or not, and i want bilstien 5100s up front but im reading ppl are putting spacers on rear coils too? if so shouldnt i get coil spacers all the way around?? i am wanting to put 37/12.50/20 on my factory wheels fyi.. i'd like to get as high as possible without making the 37s look retarded.. help please
Old 10-03-2012, 04:18 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Alot of people here run RCX lifts, I myself run a procomp lift, " adjustable shocks in the front allow you to turn that 6in lift into almost 8in, spacers in the back so if u adjust to the max your not nose high, no wheel spacers and no coil spacers in the front adjustables all the way hope this helps ill go more into detail when I can log in somewhere besides my phones browser lol
Old 10-03-2012, 04:40 PM
oh ok so is there a certain brand rear coil spacer everyone likes?
Old 10-03-2012, 04:45 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I like performance accessories
Old 10-03-2012, 06:21 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
My bad edit, I use ready lift spacers not performance accessories lol I don't even think the make rear spacers that my fault sry for misleading info
Old 10-03-2012, 08:24 PM
were you nose high on your setup without rear spacers? if so ho much and what size spacers did u go with. Im going to order the rcx 6" and 5100's tonight just need to know about the spacers and pick out a tire. thanks for the info btw
Old 10-03-2012, 09:06 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I used a procomp 6in lift kit(the cheaper of the 2)
then i added prorunner adjustables zx-2014 to the front and set them to 2.75in.
the rest in the fron is procomp except i didnt use the preload spacer so in the fron there is 7.75in of lift
in the rear i used rcx coil over, and a ready lift 1.5in spacer.
with this setup i only have 1in of rake so without the rear spacer i would be nose high .5in.
hope this helps, for more info on my lift you can check my thread in the suspension lift mod section of the forum here
http://www.ramforumz.com/showthread.php?t=122762
or my complete build thread here
http://www.ramforumz.com/showthread.php?t=121733
im rolling factory wheels and tires right now new wheels and tires will be here soon i got the tracking number on them today, so next on my list get them mounted and balanced and installed, then 3" performance accessories body lift.
Old 10-04-2012, 10:30 AM
Thanks for the help man.. I pulled the trigger on a 6" rcx lift, 37/13.50/20 toyo mt's, and bilstiens 5100's last night. The bilstiens i ordered come with the rear shocks too and it says they lift the rear 1" so im going to see how it comes out. I still may need coil spacers idk lol have to wait and see i guess. I wanna do a body lift this winter and get some novakanes put on her
Old 10-04-2012, 01:06 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Bilstiens, or any shock is not going to lift the rear of your truck. The shock doesn't support the weight of the truck, the springs do.
