Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Body & Interior
Body & Interior 1st Gen Dodge Ram Body & Interior Problems and Questions.
United Radio
Old 10-03-2012, 10:42 PM
streetvan1 streetvan1 is offline
Vehicle: ugly 88 ram
Trim Level: ROYAL s.e.
Color: White/brown
streetvan1 is on a distinguished road
Default Older round headlight grille on an 89 ram
Has anyone swapped an older style 75 ish grille onto a late 80s truck? The rad support looks the same, what problems will I run into other than the lower panel, light buckets and brackets?
Old 11-04-2012, 11:33 PM
Color: White/brown
Well, I was checking the pick n pull website today, and noticed that a 76 dodge arrived on Friday. So, I headed down there and grabbed the grille, headlight buckets, and lower valance. I brought it home, and bolted it on. The grille works fine, but the valance and associated brackets need to be modified. The bolt-up was as far as I got today, as my girlfriend had the whole afternoon all planned out for me. Next week, i'll start with the grinder and mig welder. Photos forthcoming.
Old 11-05-2012, 12:04 AM
Color: White/brown
Here she is. As you can see in the side view, it's a bit askew. The lower valance doesn't match the curve of the fender. But the griille fits nicely. Naturally, the lower valance from the newer style grille doesn't even kind of work. So my plan is to fabricate a bracket for the center of the valance to pull it back in to line up the grille, and then make a filler panel to fill the gap between the valance and the fender. I'll update more as it progresses.
