Old 10-03-2012, 10:10 PM
mEasy27's Avatar
mEasy27 mEasy27 is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500 4x4
mEasy27 is on a distinguished road
Default Fuel Leak
I had my truck in the garage for a couple months now. I am selling it, so i was doing some stuff to make sure its as reliable as possible.. I replaced all the valve stem seals. While doing this, i unplugged a couple sensors and unplugged various vacuum hoses to make room for myself between the head and the brake master cylinder.. After everything was buttoned back up, i went to started it. at first it started and but then stalled after maybe a second. then it would just crank and barely fire, but not enough to hold an idle.. Then i noticed a gas smell. when i looked, i had gas pouring out from the top of the gas tank. dont know why all of a sudden its leaking.. Im thinking maybe i have some vac lines wrong, mainly the ones that run form that solenoid looking thing on the back of the driverside valve cover to the evap canister.. but it could just be bad fuel lines. Im reluctant to think that because i havent had issue with it before and it isnt weathered, because its been in my garage. Has anyone else had this issue..
1996 Dodge Ram Laramie SLT 4x4
2002 Dodge Ram 1500 4x4
Old 10-04-2012, 12:36 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Sounds to me like you are the victim of some long term salt damage, from unrinsed off winter salt. I'd get a few buds over and slide the bed back, and see if you need new clamps, new hose, or a new fuel pump assy. Eccch... Don't feel too bad, it ain't snowing THERE yet!!! It will be here, tomorrow night...
Old 10-04-2012, 12:46 AM
mEasy27's Avatar
yeah Ill just drop the tank and take a look.. With my schedule, ill be working on it alone like always..
