Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 09-29-2012, 05:24 PM
blacknredram95 blacknredram95 is offline
Vehicle: 1995 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Black and Red
blacknredram95 is on a distinguished road
Default spark plug and wire removal
What is the best way to remove the wires in an easy way. I can hardly see the cap way in the back. Also, any tricks to removing the spark plugs on the driver's side next to the brake booster?
Old 09-30-2012, 01:24 AM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
I usually worked on GM but the best way to change your plugwires would be to do them one at a time. as far as the driver side back set, I found a little bit of space from the underside of the old chevys I used to play with. Good luck
Old 09-30-2012, 07:05 PM
Jebie Jebie is offline
Vehicle: 2008 Dodge Mega Cab
Color: Grey
Jebie is on a distinguished road
Default Plugs
OK so i spent today changing my plugs. Sounds like work but makes the job easy. Take off the tire and plastic housing under fender. Get a stool and sit there and work. Can get at all of them!!
Old 10-02-2012, 05:19 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
I'm 5'4" or so, I just laid over the radiator. I WILL say to make sure you do the wires one at a time and make sure the wire routing is the way it was. I did not route my wires the way they came from the factory and had a miss. I looked up the factory wiring, routed accordingly, and the miss stopped.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
