Place your Ad Here!
Old 10-04-2012, 12:34 AM
mEasy27's Avatar
mEasy27 mEasy27 is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500 4x4
mEasy27 is on a distinguished road
Default Heat not getting hot..
Like the title says.. I let the truck warm up to operating temps, and the heat blows cool... When i drive it gets warm, but i have it at full blast.. It is only warm when its directed to the windshield. When I switch it to blow towards me, it is really cool.. The car warms up normally, no overheating or anything.. Any suggestions??? Its a 2002 1500 btw..
1996 Dodge Ram Laramie SLT 4x4
2002 Dodge Ram 1500 4x4
Old 10-04-2012, 02:34 AM
Rep:2906
touch both hoses going to the heater under the hood, they should both be hot
if they are both hot, you have a control flap, inside the heating system that is likely broken
dodge refers to them as Blend Doors. The blend doors are used for redirecting the flow of air, hot or cold
Old 10-04-2012, 09:31 PM
mEasy27's Avatar
Thanx.. ill check that out..
Old 10-06-2012, 09:12 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
might also be your thermostat..
Old 10-06-2012, 09:35 AM
Resident Technician
Rep:1915
Start with the obvious and verify the coolant level.
Old 10-06-2012, 03:56 PM
MorePower's Avatar
MorePower MorePower is offline
Vehicle: 2004 Ram
Color: Maroon
MorePower is on a distinguished road
+1 I had that same problem with my car when my coolant was too low. it would only blow heat when I was driving, anytime I stopped it would blow cold.
Old 10-09-2012, 04:40 AM
mEasy27's Avatar
I was thinking that could be it too.. Ill be doing that first when i leave work.. also to the 1st response i got, yes both hoses running through the firewall are hot..
Old 10-09-2012, 04:43 AM
mEasy27's Avatar
Mine blows hot when i first turn it on. but within 3 -5 seconds, it cools down. Im assuming the blower is cooling the lines down and not allowing them to stay hot..
Ill be checking the coolant level, ill get a t-stat too, but i dont think its that.. the temp gauge gets to operating temps like it should when its running normal..
Old 10-14-2012, 03:53 AM
mEasy27's Avatar
yes coolant was low. thanks for the help
