Old 10-04-2012, 09:47 AM
jump150 jump150 is offline
Vehicle: 2008 Dodge Ram
jump150 is on a distinguished road
Default How do I wire a brake controller in a 08 with only a 4pin harness?
I bought an aftermarket 7pin harness for the rear. the factory 4pin plugs into it and then I had a ground and backup light wire to splice. I have left a white and black 12 gauge 14 foot wire that I assume should go to the battery and my new Tekonsha brake controller should go to the factory blue connector under the dash. Is this correct or do i have it wrong? Thanks for any advice.
Thanks
Don
Old 10-04-2012, 09:58 AM
Rep:1885
I'm a bit confused on the ground wire since the 4 pole flat already has a ground in it. I suspect the long wire is indeed for the brake controller output but can't be sure. Can you post the make and model of plug you purchased?
Old 10-04-2012, 10:16 AM
It's a Tow Ready part # 118799, and where the 2 strand 14foot wire in the instructions says it should be a blue and a balck wire, I have a white and a black wire
