Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 10-04-2012, 09:28 PM
cas390 cas390 is offline
Vehicle: 1990 D 150 2WD
Trim Level: SL
Color: Two tone blue
cas390 is on a distinguished road
Default need new front suspension
gonna replace everything up front as far as ball joints tie rods coil springs etc. what avenue should I go as far as good replacement parts. which brand? moog,dorman etc. also should I use rock auto or local parts warehouse.
Was thinking of putting on d250 coil spring or heavier duty than original. was trying to get the front end up a little higher. I don't know if going with taller coil would affect the other components. any of you guys every do this? input? please?
thanks, Chris
Old 10-04-2012, 09:47 PM
Rep:1845
Moog is a personal favorite of mine. Napa's premium line is also good stuff. I can say from experience that Rock offers exceptional service.
Old 01-12-2013, 10:36 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
Smile
thanks, Chris
I installing D250 coils I think would make a very stiff ride on A D150.
Even if you upgraded every thing to D250 all it would is make the ride stiffer upset handling. Moving your suspension to heavy duty 1/2 componets both front and rear would be eaiser and less expensive. It would stiffen up suspension but not as stiff as a 250. There are many kits to raise all types of vehicles and are safe. I would not recommend using cut coils on the front. I have on a number of times used airbags they work great and are adjustable by adding or removing air. Give a stable ride.
