Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 10-04-2012, 11:48 PM
verdesardog verdesardog is offline
Vehicle: 2006 Ram 2500
Color: Blue
Rep:29
verdesardog is on a distinguished road
Default oil pressure gauge install
I bought a used Stewart Warner mechanical oil pressure gauge to install in my truck. This is a step by step photo essay of the install.
The gauge:
Connecting the oil line to the gauge:
Had to fab a mounting bracket:
Gauge mounted in single pillar pod, plumbed and wired for lights:
Oil line connected to top port on oil filter housing:
20yr US Navy veteran (Viet Nam, Persian Gulf). 2006 Ram2500 CTD
Old 10-04-2012, 11:49 PM
Color: Blue
Rep:29
Flex line connected to copper tubing:
Cutoff valve and transition to plastic tubing near firewall for entrance to passenger compartment:
Hole marked and cut for tubing and wires in pillar cover:
Be sure to not cut supports on back side of cover:
Route of copper tube in engine campartment:
Gauge installed showing pressure with engine idling:
Wide view of install:
While I had the pillar cover off I fabricated some supports to beef up the plastic mounting posts. I did both sides of the front. While not as classy as the ones you can buy they do the job of making the grab handles MUCH sturdier:
[IMG]http://www.************************/dev/images/statusicon/user_online.gif[/IMG] [IMG]http://www.************************/dev/images/buttons/report.gif[/IMG] [IMG]http://www.************************/dev/images/misc/progress.gif[/IMG]
Old 11-05-2012, 08:15 AM
BigTJohn's Avatar
BigTJohn BigTJohn is offline
Vehicle: 2012 Ram 2500
BigTJohn is on a distinguished road
Pretty good job on complete install. Too bad you could not find a white faced gauge. Still looks good.
"Life is not too short, just that you are dead for so long..."
Old 11-05-2012, 11:22 AM
Rep:1877
I'm curious. Why the plastic tubing going to the interior? I've seen this stuff come apart (where copper wouldn't have) in an interior and make the worst mess you've ever seen.
Old 11-07-2012, 03:15 PM
Color: Blue
Rep:29
I used plastic on the inside because it is more felixible and easier to to install. I've never had any problems with plastic lines.
Old 11-07-2012, 03:16 PM
Color: Blue
Rep:29
That gauge is a classic!
Old 11-07-2012, 03:44 PM
Lowrdr's Avatar
Lowrdr Lowrdr is offline
Vehicle: 98 1500 Laramie SLT 4X4 QuadCB
Trim Level: Laramie SLT
Rep:13
Lowrdr is on a distinguished road
Obviously there is already an oil pressure gauge so do you do this to have finer granularity in the reading?
Old 12-04-2012, 07:11 PM
Color: Blue
Rep:29
granularity? there's no grain in my oil....lol
The stock Dodge oil pressure gauge is booogus....it's only a pressure switch that tells the computer when there is over 6psi of oil pressure.The computer then makes a false reading showing what the engineers thought people would want to see accorcing to engine speed and temperature.
The Cummins takes a couple of seconds to build oil pressure and when cold the pressure is much more than shown on the stock gauge. When the engine is warm at idle the stock gauge shows a false 40psi when it is really somewhere around 20!
