Surging Idle/Throttle-Help! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-05-2012, 09:58 AM
cshe091 cshe091 is offline
Vehicle: 2004 Dodge Ram 1500
cshe091 is on a distinguished road
Angry Surging Idle/Throttle-Help!
My problem is that intermittently my truck has a surging idle. It does not do it all the time, but I will get an idle that fluctuates between 400 rpm, and 1000 rpm. So far it has not stalled. Sometimes it will also rev up to around 2500 rpm as I'm coming to a stop, and push in the clutch. After it goes to 2500 it always comes down to around 650. I have replaced the TPS, Map Sensor, Idle Air Control, cleaned the throttle body, changed the spark plugs, and reset the APPS sensor. I'm not getting any trouble codes, and it runs great except at idle. I get no hesitation whatsoever going down the highway. I have had it at the dealership, and they can't get it to recreate the problem so that they can investigate. It does it probably 2 out of every 5 times it is driven. I'm getting really frustrated at this point. Does anyone have any suggestions?
Old 10-05-2012, 11:16 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Man that's tough without an engine light...
Maybe a vacuum leak, fuel pressure regulator issue...?
Sean
Old 10-05-2012, 11:32 AM
I checked for a vacuum leak using carburetor cleaner. I would think that a fuel pump or fuel pressure issue would be seen across the whole range from idle to full throttle. It is super frustrating.
Old 10-05-2012, 11:42 AM
Resident Technician
Rep:1915
Did the dealership check the PCM flash level to see if any updates are available?
Old 10-05-2012, 11:44 AM
I am not sure if they checked the PCM flash level. What would that do?
Old 10-05-2012, 12:16 PM
Resident Technician
Rep:1915
A newer version may address a problem like the one you have.
Old 10-05-2012, 12:24 PM
I just got off the phone with the dealership. They said that the firmware was already updated to the latest version when they got it. They have looked at all of the electrical outputs of the sensor, and say that they fall within range. Unfortunately they haven't been able to get the truck to idle erratically while the computer has been hooked up. They did say that the have escalated it to a star case? They are hoping to have more information within 24 hours.
Old 10-05-2012, 12:47 PM
snrusnak's Avatar
Rep:1388
EGR, IAC. I know you said you replaced the IAC, but was it an oem part? I've replaced sensors with aftermarket poor quality parts and caused running issues in the past... Also what's an APPS sensor?
Sean
Old 10-05-2012, 12:59 PM
Resident Technician
Rep:1915
APPS stands for Acceleration Pedal Position Sensor. It's used on vehicles with ETC.
Old 10-05-2012, 01:02 PM
snrusnak's Avatar
Rep:1388
^oh ok. 2004 4.7L didn't have ETC correct?
Sean
