Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-05-2012, 01:48 PM
kb8rhu's Avatar
kb8rhu kb8rhu is offline
Vehicle: 2001 Ram 150
Trim Level: sport
kb8rhu is on a distinguished road
Default Heat ??
I have a problem with my heat. I have a 2001 Ram 1500 4x4 3.9 . I start it up and warm it up. It blows cold air. If I rev it up a little the heat works fine. Let it run at idle and no heat. Would this be a bad blend door actuator ??
Old 10-05-2012, 01:50 PM
Resident Technician
Rep:1909
Since the blend door is electronic it sounds more like an issue of coolant flow to the heater core. Check the coolant level and condition.
Old 10-07-2012, 02:43 AM
kb8rhu's Avatar
Trim Level: sport
That is what i thought as well. I changed out the thermostat and changed the coolant. I still have the same problem as before.
Old 10-07-2012, 02:57 AM
Rep:2705
there is a possibility that the heater core is at least partially blocked
after your vehicle warms up, are both heater hoses close to the same temperature ?
if not, you can disconnect the 2 heater hoses at the engine end, ( it is easier to disconnect them at the end furthest from the heater )
the hose coming out of the water pump is likely the supply side, the other hose should be the return side,
Using safety glasses at a minimum to protect yourself
put air pressure or water pressure into the return hose
that should back flush the gunk in the system
Then hopefully you will put it back together & everything may work properly
You may have to Burp the air out
