Please help Guys - I'm at my wits end - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 12-15-2012, 06:31 AM
ramzilla96 ramzilla96 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Patriot Blue and Silver
ramzilla96 is on a distinguished road
My jeep wj did the same thing, mine felt like the drive shaft was coming through the floor. My u joint on my drive shaft was history. I'd replace the rear u joints whether it needs them or not ( cheap insurance) take it down the road try that, if that doesn't work find some where that can check the balance on your driveshaft
God created man, Samuel Colt made them equal.
Old 01-09-2013, 02:24 PM
desolit desolit is offline
Vehicle: 1995 dodge ram 1500
Trim Level: sxt
Color: green/silver
desolit is on a distinguished road
borrow someone's steel wheels and see if it still does it. It does sound like a tire but if you replased the tires and its still going on, the next place to check would have been the rim. 20oz of weight is ridiculous and people often give the integrity of aluminum wheels too much credit. good luck.
Old 06-04-2013, 08:13 PM
theman440 theman440 is offline
Vehicle: 2000 Dodge Ram
Trim Level: Laramie SLT
theman440 is on a distinguished road
Update - just as I suspected...bad tires. Apparently if you want tires that are true you have to spend over 200.ea. (Michelin - Pirelli). Put her up on stands and put in gear - you could plainly see both rear tires out of round. At least a quarter inch - the wheels spun true but not the tires. It appeared that the tires were seated on the rims properly too. I bought some $170 Yokohama's for the rear and it is much better but not perfect. Thanks again for the input gang... I knew I wasn't nuts.
