Old 10-05-2012, 11:21 PM
Olaf L. Olaf L. is offline
Vehicle: 2012 Dodge Ram 3500
Color: Timberline Green
Olaf L. is on a distinguished road
Default Smoother ride on 2012 3500. Possible??
I just bought the truck and was just wondering if there is a shock that will give a smoother ride than stock but still be able to take payload when needed?
Old 10-07-2012, 11:05 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Being a 3500 unless you have a load its going to be a bit stiff back there. I dont think shocks would help much because the springs won't compress much to do anything with the shocks...till loaded at least.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 10-07-2012, 11:29 AM
Colorado700R's Avatar
Colorado700R Colorado700R is offline
Vehicle: 2011 Ram 1500 Crew 4x4(Rambox)
Rep:34
Colorado700R is on a distinguished road
Choosing a tire with a taller sidewall can help a little. In example, if you test drive a new truck with 20s and another with 17s. The 17s will give a better ride becuase their is more area to flex.
Old 10-07-2012, 10:41 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
Full air ride is all I can think of.
Old 10-08-2012, 02:25 AM
Thanks for your replies. I have the 17" tires on there but I used something the guy at the GM dealership (when I was test driving). He said his trucks come with 80psi from the factory so he let some air out before I drove it. Checked the pressure on my tires and, combined with the supplemental info sticker, I was able to reduce the tire pressure which helped a bit.
