Old 10-06-2012, 01:01 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Default Who makes my rear axle?
Another member was asking if I knew who makes the axle on my 2012 2500 and I have no idea. Here is my build sheet, can anyone tell from this who makes the axle?
VIN 3C6TD5NT6CG17xxxx
Vehicle Description DODGE RAM LARAMIE 4X4 2500 MEGA CAB PICKUP
Model Year 2012
Body Model DJ 7 P 81
Color PW7- Bright White Clear Coat
Engine EZC- 5.7L V8 HEMI VVT Engine
Transmission DFP- 6-Spd Automatic 66RFE Transmission
Sales Code Description
*VL Leather Trim 40/20/40 Bench Seat
-DV Dark Slate Gray
ADB Protection Group
APA Monotone Paint
BABS 160 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags**
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CMAP Heated Front Seats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CTMS Deluxe Door Trim Panel
CUYP Storage Tray
CU3S Behind the Seat Storage / Bin
CVHP Front Center Seat Cushion Storage
CV1S Vinyl Shift Knob
CV2S O/Head Console w/Trip Computer/UGDO
DBAC All Automatic Transmissions
DFP 6-Spd Automatic 66RFE Transmission
DJBS 5,500# Front Axle
DK3S Elec Shift-On-The-Fly Transfer Case
DMES 3.73 Rear Axle Ratio
DRWS 10.50 Rear Axle
DSA Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
EZC 5.7L V8 HEMI VVT Engine
GACS Tinted Glass Windows
GFES Rear Power Sliding Window
GNCS Sun Visors w/Illum Vanity Mirrors
GNKS Rear View Auto Dim Mirror
GNZP Auto Dim Exterior Driver Mirror
GU4S Power Multi-Function F/Away Mirrors
GVBC All Vehicles W/Power Mirrors
GWA Power Sunroof
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAFS Air Cond ATC w/Dual Zone Control
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JATS Instrument Cluster w/Display Screen
JBBS Instrument Panel Woodgrain Bezel
JCBS 120 MPH Primary Speedometer
JFJS Temperature & Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKVP 115V Auxiliary Power Outlet
JKYS Power Accessory Delay
JLNP GPS Navigation
JPBS Power Locks
JPWP Power Lumbar Adjust
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRFP Pwr 10-Way Mem Drvr 6-Way Pass Seats
LAZS Vehicle Information Center
LBCS Glove Box Lamp
LCJP Overhead Ambient Surround Lighting
LDAS Underhood Lamp
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LELS Radio/Driver Seat/Mirror Memory
LEMP Exterior Mirrors w/Memory
LENP Chrome Exterior Mirrors
LETS Traveler/Mini Trip Computer
LHES Rear Dome w/On/Off Switch Lamp
LMES Halogen Quad Headlamps
LMGS Automatic Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LSAS Security Alarm
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MF1S Bright/Bright Grille
MGAS Ram's Head Badge
MMLP Body Color Fender Flares
MNES Body Color/Chrome Door Handles
MPLS Black-Out Tape
MS4S Ram 2500 Badge
MTES Laramie Badge
MUSS 4X4 Badge
MW5P Hemi Badge
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAS 50 State Emissions
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NHSP Heated Steering Wheel
NMCS Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PW7 Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RC3S 9 Amplified Speakers w/Subwoofer
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
RFHP 6.5" Touch Screen Display
RHRS Media Center 730N CD/DVD/MP3/HDD/NAV
RSCS SIRIUS Satellite Radio
RSLP Bluetooth Streaming Audio
RSMP Sirius Travel Link
RSPP Uconnect Voice Command w/Bluetooth
RSSP SIRIUS Traffic
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
SBES Power Steering
SCVS Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXES LT265/70R17E BSW On/Off Road Tires
TZGP BF Goodrich Brand Tires
WFKS 17X7.5 Aluminum Wheels
WF1S 17" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
XAA ParkSense Rear Park Assist System
XACS ParkView(TM) Rear Back-up Camera
XAM Power Adjustable Pedals w/Memory
XBM Remote Start System
XBNP Tip Start
XBSS Pickup Box
XCMP Vendor Painted Cargo Box
XEAP Tow Hooks
XEFP Transfer Case Skid Plate Shield
XFHS Class IV Receiver Hitch
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGDS Universal Garage Door Opener
XGMS Tire Pressure Monitoring Display
XHCS Trailer Brake Control
XJJP Locking Tailgate
XJ8S Body Color Fuel Filler Door
XLNS English/USA Language
XMF Spray in Bedliner
XRBP Integrated Module
XREP 40GB Hard Drive w/20GB Available
X8ZS Seat Parts Module
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X9AP For More Info, Call 888-539-7474
X9BP 1-Year SIRIUS Radio Service
X9CP 1-Yr SIRIUS RealTime Traffic Service
X9FP 1-Year Sirius Travel Link Service
YAAS Build To U.S. Mkt. Specifications
Old 10-06-2012, 01:13 AM
Rep:2625
Rear end could very well be an AAM ( American Axle & Manufacturing )
The AAM 10.5" axle, also known as the Chrysler 10.5" is found in 2500 and 3500 3rd Generation Hemi V8 Ram trucks as well as some earlier diesel and V10 Ram trucks. The '05 and newer Ram Power Wagon also comes with this axle equipped with a locking differential.
but then again, it may be a Dana 70
http://www.ehow.com/how_7475072_iden...-rear-end.html
the easy way to tell is to look at the shape of the rear differential cover
Old 10-06-2012, 01:48 AM
Trim Level: sport
Color: green
Rep:643
thanks again bikenut!!!!!!!!!!!!
Old 10-06-2012, 03:24 AM
Bikenut's Avatar
Rep:73
Thanks Yankee! Sounds like either axle is good stuff to me
