Finally...A Recall for the rear diff pinion nut! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-08-2012, 07:45 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
My trucks birthday is 4/10 but I've already had my diff fixed. Still planning to drop 4.56's in.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 10-10-2012, 08:32 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:171
So if you don't fall within the dates listed, what is different about these pinion nuts versus ours? My truck falls within the recall dates, I did the proactive tempo fix with locktite and peening the edge of the nut this last spring, now I don't regret it.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE/ CARLI ADJUSTABLE TRACKBAR
Old 10-10-2012, 09:36 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
That's exactly the same question that's been on my mind. I can't imagine the design differing at all for that from 2009 to 2010 - I guess 2011's had a different diff, but how did they pin down a build date range? It's like I just want to call the dealer and have them put the damned retainer on even if mine falls outside the build range.
I went online and mine comes up as not having any recalls available yet, but I believe notices will officially go out in November so I'm checking again. I have to dig up my build sheet and get my build date as well to confirm I'm in range.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2017 Dodge Durango GT
2012 Jeep Grand Cherokee Limited (SOLD)
Old 10-10-2012, 04:27 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
the build date is in your drivers door...on the label...
Old 10-10-2012, 05:01 PM
Turbovsix's Avatar
Rep:85
Primo - you are the man. Thanks for that heads up.
My build date is 4/10 so I guess I'm out of range. I actually wish it was in range because I'm not sure what the major difference was just in a four month span?
Rich -
Old 10-11-2012, 07:55 PM
RainmanX RainmanX is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:19
RainmanX is on a distinguished road
I am guessing
Manufacturers have multiple suppliers for any part. For example, if XYZ had a strike and caused a supply problem, the manufacturer would be seriously affected.
It's possible that the affected pinion nuts were supplied by a specific supplier. A retainer is easier to install, and reduces the possibility of changing the pinion depth when the pinion nut is re-tightened.
Old 10-11-2012, 08:40 PM
Turbovsix's Avatar
Rep:85
Hey Rainman -
Yeah, I hear you on that. But in the recall, it was stated that the problem was "lack of adhesive" or, as we know, loctite. So that's not a hardware issue, that's an assembly issue.
I guess what you're saying could be correct in that a different plant could have assembled a certain run of the differentials. I thought they were all out of American Axle, but not sure. I guess they still could be assembled at different plants.
I think I'm going to end up having them pull it and check it again anyway. It's the effects of the potential failure that have me concerned.
Rich -
Old 10-12-2012, 12:56 PM
ramrod83's Avatar
ramrod83 ramrod83 is offline
Color: Inferno Red
ramrod83 is on a distinguished road
ive also put my vin on the website and nothing showed up so i called chrysler and they said im good too even though my build date is 10/9
Old 10-15-2012, 05:26 PM
Kdubag's Avatar
Kdubag Kdubag is offline
Vehicle: 2010 Ram Crew Cab
Trim Level: Lone Star
Color: Mineral Gray
Rep:15
Kdubag is on a distinguished road
Same thing with me.
My build date falls within the "recall range" but website and Chrysler rep state I'm okay and no recall. Strange.
Old 10-15-2012, 09:16 PM
sterling archer's Avatar
sterling archer sterling archer is offline
Vehicle: 2010 Dodge Ram 1500 4x4
sterling archer is on a distinguished road
Outstanding news! Hopefully nobody has been hurt due to this issue. Just for kicks and grins I looked at my diff and it has some older looking staining on it...no splatter that's been recent and the gas tank is clean but still...every time I drive the truck this issue is on the back of my mind and quite honestly it really makes it difficult to enjoy my time behind the wheel. Where on your build sheet did you find the man date? Chrysler sent my sheet via email but it doesn't mention a man date...
Virginia is for lovers. Hemi lovers.
