Do I need winter tires? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-07-2012, 07:00 PM
themightye themightye is offline
Vehicle: 2012 Ram
Trim Level: Bighorn
themightye is on a distinguished road
Default Do I need winter tires?
I just bought a 2012 Ram crew cab, 4x4. It came with 20" Goodyear Wrangler tires. Live in Toronto, not a great deal of snow in winter, but there are some days with a great deal of it. I want to know if I should buy a separate set of winter tires. I did with my GCSRT8, and they were a lifesaver.
Old 10-07-2012, 07:04 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Is it 2wd or 4x4? If it is 4x4, then no. Run the stock 20s you will get enough traction to get you through, I live in Maine and we get plenty of snow and no issues with mine. If it is 2wd. I would put some weight in the back and test it in the first snow before I made an expensive purchase of tires. good luck friend.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 10-07-2012, 07:10 PM
lmcanje lmcanje is offline
Vehicle: 2012 Ram
Rep:13
lmcanje is on a distinguished road
Winter tires are for stopping and turning, not for pulling away from a stop sign.
Old 10-07-2012, 07:12 PM
Vehicle: 2012 Ram
Trim Level: Bighorn
4X4. Thanks for the advice.
Old 10-07-2012, 07:14 PM
Rep:69
4x4 No worries, run her! Your gtg.
Old 10-07-2012, 07:20 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Id like to know this too as I am considering winter tires.
Reason being is I have Toyo MT tires and also in Toronto where we do get snow.
Last year we fortunately didn't
I was thinking of running Nitto Terra...should I be looking at this considering I got MT Tires?
sales@revelperformance.com
Old 10-07-2012, 07:26 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Winter tires do more than just get you to go in snow, winter tires are designed for cold conditions, not necessarily for snow or ice. it reads like you are thinking in terms of “snow” tires that are really no longer produced. Todays Tires are "winter Tires". Developments since that era have concentrated on the fact tire treads are susceptible to temperature. The effectiveness of all-season tires drops off sharply as the thermometer drops below 7 degrees Celsius and even more so for "summer Tires" That is the point at which “winter” tires start to gain the edge. As the temperature drops further, the gap between the two widens as well, regardless of surface conditions. Being able to get going at a stop sign is irrelevant if you can't turn a corner on an off ramp cause you have no grip below 0, or stopping when arriving at a corner or the car ahead of you who has winter tires decides to stop in your face. How much is the cost of damage to your truck or a life to a few hundred for some tires. Ya maybe your only gonna use them for 40% of the winter period, but it takes that 1% for something to happen where you might just say "I should of got some winter Tires". Also, they will last you for 4 - 6 years depending on how you maintain them. What if you have to go up north from GTA area? What if its an exceptionally cold winter. All things to think about before Old man winter comes along. JMO
Old 10-07-2012, 07:29 PM
Grubrunner's Avatar
Rep:3883
My Toyo MT's on my previous Ford was brilliant in the snow.
Grub out!
Old 10-07-2012, 07:32 PM
Revel Performance
Rep:1804
Really?
Mine have only 500 miles on them so they are still new.
I may run them this winter to see how they handle. If it is not to my liking, I will grab winters.
Still undecided as I typically have winter and summer sets for each of my vehicle
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:134
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
MT (mud terrain) tires suck in winter. The wider the tire the worse they are too. Get a narrow winter tire on all four corners, don't piss around - you'll thank me when the snow flies.
