Old 10-08-2012, 11:18 PM
trevor216051 trevor216051 is offline
Vehicle: 2001 Dodge Ram
trevor216051 is on a distinguished road
Angry 01 Ram Exhaust Plugged Again
Ok, Here is my story.
About a year ago I drove up from Vancouver to Kamloops and drove around for a couple days hunting and fishing etc.... and on the way back up the Highway (Coke) The engine started hesitating under full throttle. Needless to say I had to nurse it back to home to figure out what was going on. After a bit of research I learned that my exhause was plugged. I got my cat taken off at a muffler shop and a straight pipe put in. This fixed it right up and it sounded pretty good too. Then after another trip up Kamloops the same thing.... I thought it might have been air filter but checked it and it was fine. I figured that it was the exhaust and also got the plenum gasket done at the same time. (ordered the one through hughes engines) I thought that would be the end of my worries. Now once again the same hesitation is coming and power is down to about 70%. Someone Please help me? Had to unscrew both O2 Sensors to get some flow there, and that helped. Any thoughts would be apreciated.
Old 10-09-2012, 09:59 AM
Rep:1885
Have you actually done a backpressure test to verify a restriction? If there is one and the converters are gone, I might suspect the muffler has deteriorated inside.
Old 10-09-2012, 01:14 PM
Default Re: plugged exhaust
Haven't done a back pressure check, just started doing this last night. I had to pull my o2 sensors off so my exhaust had some flow, which helped. I am pretty sure you are right that the exhaust is suspect. Brand new flow master, tho. Any ideas what could be causing the buildup? I had the new plenum kit installed.
Old 10-12-2012, 03:58 PM
Unhappy Rpms stay up with clutch in!
It turns out its not the exhaust like I thought. I guess I'm too used to the exhaust. Plugging up on me.
I re-routed a few plug wires so they didn't cross, which made a big difference! No more hesitation so far.
My other problem which happened at the same time is that when I am downshifting, my rpms stay up when the clutch is in and my tach hits 1500 to 2000 rpm and just stays there until I put it in gear or stop. Any ideas on this?
Old 10-12-2012, 04:12 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If the wires were jumping spark then replace them. Sounds like the truck needs some regular maintenance, a tune up. Start there, the cheap/easy things first. Any engine lights/codes?
Hanging idle is usually an intake leak/vacuum leak.
Sean
Old 10-12-2012, 04:31 PM
I have replaced the plugs, air filter ,plenum. I guess I will grab some new wires and throw those on. I do have a check engine light for smallleak in evap that has been on there for a while. My mechanic couldn't find it. Any ideas how to investigate this further?
Old 10-12-2012, 04:44 PM
snrusnak's Avatar
Rep:1385
I'd start with wires. I'm not familiar really with EVAP systems so don't know if it could cause any issue, I think it's purely emissions related. I assume you tried the gas cap? Is the code P0440? P0441? Gas cap usually fixes these codes. The rubber seal on the cap deteriorates with age.
Sean
Old 10-12-2012, 06:52 PM
Just replaced all the wires, took it for a drive, no hesitation but the rpms are hanging up when I have the clutch in and downshifting. Anyone have suggestions? Cleared the evap code and nothing else has come up
Old 10-14-2012, 05:27 PM
snrusnak's Avatar
Rep:1385
So the evap code didn't return?
As far as the hanging idle I'd think intake leak of some sort. Only other thing could be fuel issue like maybe regulator???
Sean
hesitation, plugged exhaust
