B-Pillar tape removal - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-15-2012, 09:19 PM
cynjon's Avatar
cynjon cynjon is offline
Vehicle: 2009 Dodge Ram 1500 Laramie
Color: Gray
Rep:30
cynjon is on a distinguished road
Default B-Pillar tape removal
I finally got around to removing the ugly (and wrinkled/cracked) tape from my door pillars. Why on earth would Dodge put that crap on a $40K+ truck?
Anyhow, it had started to cool down by the time I got started, so I had lots of adhesive that stayed behind. I wiped it down with Goof-Off and it cleaned right up. I used a heat gun on the rear door tape but it really is a 3-handed process and I decided to wait until tomorrow to do the passenger side.
It looks much better, IMO...glad I was able to find great info on this forum to convince me to pull the trigger!
Old 09-15-2012, 09:48 PM
Power247's Avatar
Power247 Power247 is offline
Vehicle: 2012 Ram 2500
Color: True Blue
Rep:22
Power247 is on a distinguished road
I really like the way the trucks look without the black tape on the doors. I'm still working up the courage to start it on my own truck. It looks easy enough but... once you start you can't just change your mind.
Greg
2012 2500 4x4 CTD Big Horn CCSB 3.73|Flo~Pro|SIMS|XRT Pro|Edge Insight CTS|Infinity|JBL
2009 1500 4x4 HEMI Big Horn CCSB 3.55|Volant CAI|18" Magnaflow|Airlift1000|Superchips Flashpaq 3865 - SOLD
Old 09-15-2012, 10:40 PM
Rep:1388
power, just takes some patience, but is easy. When I did mine it was ripping, not all coming off in one piece, so it just was a mess, but was easy enough. Then had to use adhesive remover to get the glue off. Be careful and test the adhesive remove under the bed or something first to make sure it won't take the paint off.
Old 09-15-2012, 10:55 PM
cynjon's Avatar
Color: Gray
Rep:30
Once you start, you won't WANT to change your mind.
I peeled the tape off the driver's door pillar without heat and it left a LOT of adhesive behind. The rear door on the same side came off a lot cleaner (and all in one piece) with a little heat. Hard to do with only two hands though...if a guy did it on a nice hot day it would probably be a quick and easy job. Definitely worth the time and effor though!
Old 09-16-2012, 12:23 AM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2015 RAM 1500 sport
joelwalls is on a distinguished road
i really like the way it looks i also didd mine and removed the badges looks super clean
Old 09-16-2012, 09:26 AM
BB0204's Avatar
BB0204 BB0204 is offline
Vehicle: 2010 Dodge Ram CC
Rep:22
BB0204 is on a distinguished road
Yea I did my first truck on a warm day and it was much easier then the second time when it was alittle cooler. The second time some glue stayed behind but goo gone took it right off with no problems.
14" Magna Flow Exhaust, Painted Color Matched Calibers, T-Pillar Tape Removed, Tinted Windows, Honeycomb Grille Insert, Bed Rug, RES NAV unit, E-Z Down Tailgate, Mopar Mud Flaps
Old 10-09-2012, 12:46 PM
Nymisus Nymisus is offline
Vehicle: 2012 Dodge Ram 1500
Nymisus is on a distinguished road
I can't tell if my truck has that or not. Its a 2012 sport 1500 black, it looks the same as the rest of the truck, did they stop doing this?
Old 10-09-2012, 12:54 PM
Rep:1388
black trucks don't have it.....
