Old 10-10-2012, 11:56 AM
I won't be able to link the thread here.
Google doughboy 6" lift dodge ram 1500
It's a black express with pocket flares.
And he will be prob doing wheel spacers to bring them out.
If you are running pocket flares, I would do the -24 offset.
Old 10-10-2012, 05:06 PM
rdnlsi rdnlsi is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Mango Tango Orange
rdnlsi is on a distinguished road
Talking
Email is not complete... I also can't pm cause I lack in posts.... If anything you can email me at rdnlsi@gmail.com and I'll send ASAP...
Old 10-11-2012, 02:27 AM
Ram 1 Ram 1 is offline
Vehicle: 2012 Dodge ram 1500
Ram 1 is on a distinguished road
Checked out doughboy's ride.I agree the wheel need to stick out more.He said he was running a 20/10 with a +1 offset.Does that mean -12mm?offset.I thought +1 meant stock offset.
Old 10-11-2012, 05:57 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Originally Posted by Ram 1 View Post
Hi guy's.My 6 inch bds lift is on the way.I plan on running 35's,and was wondering if you can get away with a 20/10 inch wheel with a 24mm backspace or 20/10 inch with a 12mm backspace.Hope to have the wheels stick out a bit from stock as I am putting on fender flairs.A SMALL amount of rub would be ok.
I just don't want the flush look to the body.
Cheers John
Are those wheels +12mm / +24mm or are they -12mm / -24mm offset?
How far out will the flares stick?
He is running 20x9 inch wheel with +1 offset not 20x10.
So comparing the wheels, if they had the same offset (lets say +1) the 20x10" wheel will stick out 1/2" further than the 20x9" wheel. The +1 is just that, +1mm offset from the center of the wheel.
Just since -12mm was mentioned in this post ill run with that. In comparison if you run the same flares (as doughboy) and a 20x10 -12mm offset wheel your wheel will stick out 26mm further than they do on his truck. If you go with the -24mm add 12mm to that so they will stick out 38mm further than his.
If they are +12/24 then the 20x10 +12mm wheel will stick out 2mm further than his do and the 20x10 +24 will actually retract by 10mm (so his would stick out 10mm further than yours).
Hope that helps some.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 10-11-2012, 10:35 AM
Ok, he prob has a 20x9 then if he has a +1 offset.
20x10 only comes in a -12 or -24 offset.
I would do a minimum of -12 offset if running flares (OE flares) if pockets flares, I would still run the -24 offset
+1 is the offset if 20x9
Stock wheels are 20x9, +19 offset
Old 10-11-2012, 12:06 PM
Thank's so much guy's you have been a great help.
I'll post so pic's as soon as I get the wheels and tires on.
Old 10-12-2012, 01:18 PM
When you getting the wheels?
