tutorial on how to paint the inside of your headlights(lots of pics) - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-21-2012, 09:41 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
lol kijiji rymed with fiji so eh that came to mind ha
-Pat-
Old 10-21-2012, 09:50 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
Hahaha alright man, totally makes sense :P
Old 03-21-2013, 05:09 PM
GymRat's Avatar
GymRat GymRat is offline
Vehicle: 2009 Ram 1500
Color: Mineral Gray
GymRat is on a distinguished road
JHinkle, any way you could fix the picture links in the original post? I'm about to do mine and this looks like an extremely informative thread!
Old 03-21-2013, 05:36 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
I will see what I can do, I can not edit the original post however I can repost it here, I will try to get it up before then end of the day
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 03-21-2013, 05:55 PM
GymRat's Avatar
Color: Mineral Gray
Thanks brother!
Old 03-21-2013, 06:01 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Just saw this now. Awesome write up Jeremiah! Does anyone have pictures of doing this to quad headlights on a black truck with a chrome bumper and grill? I'd curious to see how that would look because then maybe I'd consider doing it.
Old 03-21-2013, 06:16 PM
TonyG-'s Avatar
TonyG- TonyG- is offline
Vehicle: 2010 Ram 1500
Rep:192
TonyG- has a spectacular aura aboutTonyG- has a spectacular aura about
Very nice write up.
Old 11-06-2013, 12:38 PM
BlackedOutNinja's Avatar
BlackedOutNinja BlackedOutNinja is offline
Vehicle: 2013 Ram Sport
Trim Level: sport
Rep:56
BlackedOutNinja will become famous soon enough
Im waiting to see if he can get the rest f the pics working.
Brrraaaaaaapp!!!
Old 11-06-2013, 06:49 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Originally Posted by Bully's Performance View Post
So yesterday i found out that my blacked out headlights with projectors were on a backorder and it will be 2-3 months before they get here so what it the solutions? ill tell you i actually had the entire weekend off so it was removing the headlights from the truck, baking them, removing the lense and then painting the chromed out parts, does this solve my projector problem? no. but it looks bad ass. so here we go step by step with many many pictures.
Now i did this on a 2012 1500 QC 5.7l st, so that is what these directions are going to be for.
First we need to open the hood and locate the radiator cover shouldnt be to hard as it is right there lol, now they are just push pins that hold it on so you need to lift up on it to pop them and then set the radiator cover asside.
now we need to locate the 2 bolts holding the grille on and remove them, once they are removed there is two clips simply pull strait up on the grille and it will come out, now set it asside somewhere preferrably with the raditor cover so we dont go loosing anything(remember if you dont want to loose bolts always put them back in the whole you found them so they are there when you go to reassemble.)
now once the grille is off and the readiator cover is removed this is what you should have
now we can start to work on removing the headlights, each one is held is by 4 bolts and a white clip.
now for the easy part, remove the to bolts on the front of the assembly.
locate the flap in your wheel well plastic and open it
now remove the 2 bolts one should be right in front of you if it were, and the other kinda of up and arround the corner you can see it from the whole in your wheel well plastic though.
now you should see a white pin slider looking thing simply push it up all the way.
now go back around front and pull the headlight out, remove the 2 bulbls and set it somehwere lense up. and repeat on the other side
we go into the house or shop now, remove the rubber grommets from the back of the assembly and then preheat your oven for 250 f.
place the assembly lense up on a cookie sheet or something of the equivelent and then place it in the oven for 10 minutes.
now pull it out and take a flat head screw driver and start working your way around the lense and the assembly prying it loose from the glue(i did it by prying it loose in the corners and then was able to just pull it apart with a little force. ) while its hot you can also remove as much glue from the lense and housing as possible it will make for a much easier time putting it all back together later.
now remove the chrome pieces from the lense, and take out the yellow plastic piece.
Post 1 redone with images
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
once we have done this we need to set the housing and the lense asside somewhere. and then take your chrome pieces and some kind of a scratch pad and scratch the hell out of it.
now we go to a well ventilated room and beging to paint. I used a black caliper paint in a spray can from the local auto store(i bought 2 it was like 15$ and some change) now if you use the same type of paint i have spray on one coat, wait 10 minutes, spray on another and repeat as many time as you feel necisary in an hour,(i put on 6 coats).
now once that one is all painted set it asside somewhere to dry and cure, and place the other assembly in the oven for 15minutes and repeat the rest. this is kinda a crappy picture looks alot better than that in person.
now let everything set for 4-6 hours(this would be a good time to clean the inside of the lense), once everything is nice and dry take your assembly and put it back in the oven at 250 for 5minutes(just the houseing not the lense or the piece you just painted) we do this to make the plastic workable again. while it is in the oven take the peice you painted snap the yellow plastic back in and then snap it back into the lense very very carefully.
now when your 5 minutes is up take the housing out of the oven, run a bead of hightemp silicone around it and then take you lense assembly and press it in there, use some clamps to hold it together while you silicone sets. now let it sit for another 4-6hours.
and repeat on the other side.
Post 2 redone with images
