New updated plate for TLC system - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Diesel Forums!
Dodge Caliber
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Place your Ad Here!
Old 10-09-2012, 11:24 PM
hemiou812 hemiou812 is offline
Vehicle: 2011 Dodge ram sport crew cab
hemiou812 is on a distinguished road
Default New updated plate for TLC system
I installed my TLC system on my 2011 sport two weeks ago and everything went very smooth, easy install. I installed the updated top plate TLC sent me instead of the original that came with kit. My only concern is the new plate doesnt match up to the bump stop like it should and the air bags on both sides do not sit level. I am afraid of damaging the airbag so I have replaced these new plates with the origial top mount plates that came with the kit. I know I had them installed correctly but the slot on top of plate never would seat into the bump stop location. Just curious if anyone else has had this problem. Side note, I also installed the wireless one kit and man this makes it simple to pump up or deflate airbags.
Old 10-14-2012, 07:23 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Let us know how you make out and please keep us updated......
Old 10-14-2012, 10:02 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
I installed the updated top plate, and I have no issues, it fits right in the hole its supposed to. I am wondering, did you install them backwards? I only ask because I did that the first time. They might have to be turned around.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 10-21-2012, 11:04 PM
Bluebee Bluebee is offline
Bluebee is on a distinguished road
so i also got the top plate, but not sure I follow how that metal piece that sticks up is going to go into the bump stop hole? anyone got a good picture of how this is supposed to look, the directions had a tiny picture....any insight is appreciated.
Old 10-22-2012, 07:46 PM
ArmyofOne's Avatar
US Army Retired
Rep:1230
http://www.youtube.com/watch?feature...&v=qw3mWWMQoOs
Here is a video of a my total load control install. at the end of the video you will see my updated top plates and that they do indeed fit into the bumpstop holes. Looking at your axle from the rear, the plates must be installed like so:
Drivers Side Passenger Side
______l__ Differential __l______
EDIT: Found a pic of what its NOT supposed to look like. If your plate is in place like this, flip it 180 degrees so the "tab" that sticks up is lined up with the bumpstop hole.
Old 10-26-2012, 06:29 PM
If that's the pic of what it's not supposed to look like then you should fix your drawing cuz it's wrong as well....
__!______diff_____!__ that works better when installing......
also you guys have to do something about the driver side that hits the spring, most guys won't have the tool to get the suspension to fully hang in order to move the spring, just my advice as I find that piece a real pain, other then that it's a nice setup.
Old 10-28-2012, 10:19 PM
ArmyofOne's Avatar
US Army Retired
Rep:1230
Yes the pic is what its not supposed to look like, i just put my diagram up backwards like a knucklehead. Mine are installed the way you descibe above and work perfectly!
As for the spring rubbing, you dont need to compress the spring. Simply jack up the truck by the frame (not the axle) so the spring unloads. Once the tire is off the ground, the spring is unloaded enough you can grab it and rotate it.
