Old 10-12-2012, 09:22 AM
Gatorhunter Gatorhunter is offline
Vehicle: 2004 ram 1500
Gatorhunter is on a distinguished road
All cold air intakes seem to be that way unless you run pipe out side like a snorkel. What would you suggest? I really appriciated the info on the ex aughts you gave I always thought flos were the way to go. Thanks,
-Gator
Old 10-12-2012, 09:26 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Well there are some intakes that have enclosed boxes that would be the way to go. Honestly the stock intake is pretty good with one downfall. It has a nice large filter in an enclosed box but draws air from the fender well which draws air through a ~1" hole near the headlight. Many people use a drop in high flow filter, and just run a tube from the inlet of the stock airbox to somewhere like under the bumper to get more airflow(and cold air). Some also replace the resonator(between the airbox and throttle body but this does very little for performance, it's mostly for looks. If you get a drop in filter ~$50 and just run a different pipe from the airbox you'd be as good as any other intake(maybe even better). I use an airaid dry drop in(oil less) and have the airaid modular intake tube(mainly for looks like I said above) and run a tube down under the bumper(temporary). I plan on making a ram air scoop out of FG or alum one day to feed the stock airbox. This would be better than any CAI on the market.
Sean
Old 10-12-2012, 09:27 AM
99gp's Avatar
99gp 99gp is offline
Trim Level: SLT Sport
Rep:155
not all of them are going to be open. http://www.autoanything.com/air-inta...fcuh4aod_lyatg is a closed system
Old 10-12-2012, 09:31 AM
snrusnak's Avatar
Rep:1385
^yeah there's a good example.
The thing is most of them still draw air from that same ~1" hole, so really if you used the stock airbox and came up with a good way to draw air to the airbox from outside the engine bay you'd be better off than those ones.
I know how I'm going to do mine but i'ts fairly involved and I haven't got around to it. My buddy and I were going to try and make them and sell them but we decided against it and are just going to make one for my truck. It'll be significantly easier to make one(don't need to save the mold) than to try to make a reproducible piece.
Sean
Old 10-12-2012, 09:34 AM
99gp's Avatar
Rep:155
^^^ you are correct. The best way to go if you want something like what I posted is go all out and get it with the scoops
Old 10-15-2012, 03:10 AM
Cobra42988 Cobra42988 is offline
Vehicle: 2004 dodge ram 1500 quad cab
Cobra42988 is on a distinguished road
Single in dual out flow master dumped with two 4" x 22" echo tips right before the rear axle. Sound amazing and only cost 80 bucks if you know how to weld.
Old 10-18-2012, 09:42 PM
mdksdmf's Avatar
mdksdmf mdksdmf is offline
Vehicle: 2004 dodge ram 1500 4x4
Trim Level: SLT standard cab
mdksdmf is on a distinguished road
Yeah IMO 20hp is still worth the $300 especially with the other features you get. Just unfortunately for you guys you don't gain as much with the older 4.7L.
Look into diablo predator and SCT they are good as well. Superchips just has great performance compared to diablo in my experience(SC tunes ran faster 1/4 miles than the diablo tunes) along with other things like easier starting with the SC compared to the diablo(SC did not advance timing at startup where as diablo did and made it difficult to start). And SC gives you transmission tuning.
I have no experience with SCT though but hear great things.
very good info. thankyou. i think i will be getting the superchips for my intake and exhaust, and the trans tuning is a nice touch too. does the SC work as a flash? or do u have to keep it plugged in to the OBD? im guessing it is like a cobb acessport
"cry havoc and let slip the dogs of war" - shakespeare
Old 10-18-2012, 09:55 PM
snrusnak's Avatar
Rep:1385
it's a flash, once you tune the ecm you unplug the handheld device.
Sean
Old 10-23-2012, 09:05 PM
mdksdmf's Avatar
thanks for the info
