Fan does not work anymore - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 10-10-2012, 11:13 AM
RadicalRoadie RadicalRoadie is offline
Vehicle: 2003 Dodge Ram
RadicalRoadie is on a distinguished road
Default Fan does not work anymore
Hello all. The fan stopped working in my 2003 Ram 1500 (4.7) 110,000 km
I was working fine then suddenly stopped. No speeds work whereas before all speeds were working.
I have seen 1 post on here that indicates the fan resistor under the dash is the culprit if it only works on High; I just want to verify that this would be the same fix if it totally stops.
The fuses all look good so that's not it.
Thanks in advance!
Old 10-11-2012, 11:44 AM
Resident Technician
Rep:1915
Yes, this is the most likely cause with the HVAC control head as the next most likely suspect. Check for power to the blower motor first to make sure you don't have a blown fuse or bad TIPM.
