Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 10-10-2012, 05:02 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Default Octane question
I was told using higher octane will minimize any harmful effects that ethanol causes. I live in the east and ethanol is a 10% mixture. Is this true?
Old 10-10-2012, 05:21 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
No, higher octane ONLY provides more detonation resistance. For optimum performance/mpg use 89 in your hemi. You can also use 87 with little to no difference.
Sean
Old 10-10-2012, 05:38 PM
Rep:2705
your Owners Manual tells you about gas octanes
unless you are running your vehicle for racing, forget high test gas
it is a waste of $$$$$
Old 10-10-2012, 07:22 PM
EXPRESS25C's Avatar
EXPRESS25C EXPRESS25C is offline
Vehicle: 2012 Dodge Ram Express RCSB
Trim Level: RCSB - Express 25C
Color: Diamond Black
Rep:83
EXPRESS25C will become famous soon enough
I run 89 ... seems to run great. 6,500 miles on the odometer so far ...
"Excess is Best"
Old 10-10-2012, 08:55 PM
royw's Avatar
royw royw is offline
Rep:39
royw is on a distinguished road
I'm 3 weeks into a 3 month test of 89 octane. I have a year's baseline on 87 octane (15.00 MPG). Basically it needs to increase mileage about 0.8 MPG to justify $0.20 more per gallon.
What seems to effect mileage the most is your driving habits and terrain (city, hilly, highway,...)
Old 10-10-2012, 09:32 PM
Colorado700R's Avatar
Colorado700R Colorado700R is offline
Vehicle: 2011 Ram 1500 Crew 4x4(Rambox)
Rep:34
Colorado700R is on a distinguished road
There is more chemical energy in lower octane fuel. If two fuels are equal except for octane, the lower octane will produce the greater heat/gas expansion in the cylinder. The key is quality imo, not octane. I like shell gas for that reason.
Ps. If you're at high elevation like me you can run lower than 87 perfectly safe.
Old 10-10-2012, 09:39 PM
I push the skinny pedal
Rep:3308
10% ethanol won't hurt your engine in any way, but anything over 15% does pose a problem because you would need to scale the injectors to spray more fuel as higher ethanol content fuels need a lower air to fuel ratio to reach optimal burn without leaning out the cylinders.
Kurtis
Old 10-11-2012, 09:48 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
My truck doesn't "like" 87 octane, so I've learned to run 89...
My mileage will drop almost 2 mpg, and it just doesn't sound as though it's running as well. It could all be in my head, but it doesn't really matter.. LOL the butt dyno says it all
Exco
Bill
Old 10-11-2012, 10:03 AM
Grubrunner's Avatar
Rep:3883
Nailed it.
Grub out!
Old 10-11-2012, 10:05 AM
Grubrunner's Avatar
Rep:3883
I always thought levels greater than 20% were the issue..... no?
I may be wrong
Grub out!
