Old 10-11-2012, 01:46 PM
BerryToyz BerryToyz is offline
Vehicle: 2012 Dodge Ram 1500 Express
BerryToyz is on a distinguished road
Default whats the difference between dual mufflers and single muffler with dual inlet/outlet
I've been searching for Maggie exhausts and came across alot so now im just wondering what the difference is between 1) Two single pipes running to each of its own muffler vs. 2) Two pipes running to one dual inlet/outlet muffler with a "y" vs 3) Two pipes runing into a "X" with its own mufflers. I looking for Hp gains/gas mileage/and a little kick of deep tone. Thanks for all comments!
Old 10-11-2012, 06:34 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Hello BerryToyz. Well in my opinion, it depends on where you want the power to be bud. The low end benefits from having a little backpressure so I would have to go with a single in to a single or dual out type muffler. If you will spend most of your time in the mid range to wide open throttle, then definitely go with true duals with an X or Ypipe all the way bud. And seeing that BullyDog is releasing a tuner by mid November(as Clark@AutoAnything states), you will get the big three benefit, i.e., intake, exhaust, and a tuner.
Old 10-13-2012, 06:04 PM
Thanks for the help. Would you say that one would benefit more than the other as far as HP?
Old 10-13-2012, 07:24 PM
Gantman's Avatar
Rep:974
BerryToyz; the only real way of verifying HP gain is by throwing her on a dyno bud. If you take the plunge and have the money, I think a lot of people here would love to see data showing HP numbers with a stock, a catback system, and just dumped(turn down or cutout) right after the cats. But as to your question where max horsepower gain is at with exhaust systems; Always wide open and no restriction, until you hit the top of the powerband or limiter.
Old 10-17-2012, 09:12 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
yea true duals "supposedly" put out more power whether an h or x but no one will ever dyno a y pipe vs an x pipe vs a h pipe.
-Pat-
Old 10-17-2012, 01:17 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If sized appropriately, an x pipe, h pipe, and y pipe setup all are pretty close to equal in terms of hp/torque. Often times though people oversize y pipe systems and lose some low end power.
Don't listen to those who say you need back pressure for low end, or whatever else they come up with. That myth will never die. Regardless, it is false. Back pressure is ALWAYS bad for hp potential, you want free unrestricted flow. What most people don't realize is too big of a diameter exhaust pipe will slow down exhaust gas velocity, causing a loss in power.
Sean
Old 10-18-2012, 01:24 AM
Thanks for the anwsers. So if their close in hp/torque would it be worth paying the extra $100 bucks for a second muffler for the true duals??
Old 10-18-2012, 06:03 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
I agree snrusnak, i have never seen a drag racing car (I am sure they are going for max hp and speed) with mufflers. All you see is fire coming out of straight pipes right off the engine. I am thinking they know the scoop.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 10-18-2012, 07:48 AM
BlackHemI's Avatar
Rep:296
just buy a dual inlet muffler and single out and flip it so the 2 are connected with the duals...chefred has this set up and im going to do mine like this so i dont have to buy another muffler
-Pat-
Old 10-18-2012, 07:52 AM
snrusnak's Avatar
Rep:1385
Yeah really the most cost effective way is a y pip setup with single muffler, doesn't matter if the y pipe is before the muffler or in the muffler. It will perform basically the same as a good dual setup with crossover. You might leave a couple hp on the table but it's significantly cheaper and also keep in mind lighter. Is 5 hp worth 10 lbs? I dunno....maybe?
With your truck, don't go larger than 2.5" for the duals before the y pipe and don't go larger than 3" for the single after the y pipe.
Sean
