Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Place your Ad Here!
Old 10-18-2012, 08:33 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
sean, im going to swap my y for an x then run into the di/so muffler, this will be ok right?
-Pat-
Old 10-18-2012, 08:36 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
yep, you'll essentially have the same setup as fred except he has an h instead of an x.
I tried to think about this setup one night, to figure out how it works and all the theory, etc behind it, and my head just about exploded. So I gave up and will just say that his truck hauls ass so it must be a good setup lol.
Sean
Old 10-18-2012, 09:07 AM
BlackHemI's Avatar
Rep:296
lol yea true that, so should we do an h instead of x?
-Pat-
Old 10-18-2012, 09:42 AM
snrusnak's Avatar
Rep:1388
Don't really think it matters. Most people think an x is better but it's probably not going to make any difference. Personally I think an h is better, just seems like it'd flow better...
Sean
Old 10-18-2012, 10:49 AM
BlackHemI's Avatar
Rep:296
got a picture of a good h pipe set up or schematics?
-Pat-
Old 10-18-2012, 10:54 AM
snrusnak's Avatar
Rep:1388
It's hard to screw up an h pipe. It's somewhat easy to screw up an x pipe. If you merge the x too tight you will create restriction. They are pretty much the same though as far as results in hp from what I know.
Sean
Old 10-18-2012, 11:43 AM
BlackHemI's Avatar
Rep:296
i was gonna buy a maggy one just like the y. already cut and finished, just need welded on
-Pat-
Old 10-18-2012, 11:44 AM
snrusnak's Avatar
Rep:1388
Yeah they are nice, stamped...
Sean
Old 10-18-2012, 02:27 PM
Zevox's Avatar
Zevox Zevox is offline
Vehicle: 2014 Ford Mustang
Trim Level: GT
Color: Race Red
Zevox is on a distinguished road
Originally Posted by BerryToyz View Post
Thanks for the anwsers. So if their close in hp/torque would it be worth paying the extra $100 bucks for a second muffler for the true duals??
Don't forget about a dual in/dual out with a build in X design, such as a Magnaflow 11386. Plus you can cheat and just reuse your stock dual tips if you want. All the exhaust guy will have to do is cut out the stock y-pipe and muffler and replace it with the new muffler and a little bit of pipe so it should be cheap. On top of that you can leave your stock resonators to cut down on drone and volume if you want.
When I ran had my exhaust ran the guy cut everything from the y-pipe back out and put all new stuff, including tips, for $360, so just a muffler swap should be cheap. I only ran new tips because my were crazy bent and misaligned from the factory.
