need a lil lift help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-11-2012, 03:55 PM
ramrod83's Avatar
ramrod83 ramrod83 is offline
Color: Inferno Red
ramrod83 is on a distinguished road
Default need a lil lift help
im keeping my factory 20s on my 2010 ram but im going with 35/12.5/20 mickey thompson bajas and i know i need to lift it and im want to lift it at least 4 inches but i have no idea about rubbing or backspacing...any help would be much appreciated...thx
Old 10-11-2012, 04:02 PM
manndhb3's Avatar
manndhb3 manndhb3 is offline
Vehicle: 2012 Ram 1500 BIG HORN Crew4x4
manndhb3 is on a distinguished road
You will have no rubbing with a 4in Suspension lift and 35x1250x20s on Stock wheels. I only have the spacers because I wanted a wide stance with my fender flares and I liked the look of the stocks.
JBA Shorty Headers, Magnaflow Y Pipe, Flowmaster 40 Series Muffler, K&N 63 Series CAI, AirAid Throttle Body Spacer, Retrofit Cabin Air Filter, Mopar RAM Slush Mats, Hypertech Calibrator, Stubby Antenna, DeeZee Tailgate, Debadged, Westin Step Bars, Westin Bull Bar, Putco Chrome Mirror Covers, Rampage LED Light Bar, Truxedo Rollup Tonneau, Rhino Lining, Bushwacker Color Matched Fender Flares, Rough Country 3.75 Combo Lift, 35x1250 MTs, Remote Start, Sunroof
Old 10-11-2012, 04:05 PM
ramrod83's Avatar
Color: Inferno Red
great thanks...thats another question i had about spacers i also want that wide stance but also hearing that they fail sometimes....thinking maybe id be ok with american made??
Old 10-15-2012, 10:06 PM
manndhb3's Avatar
[B]I have the Rough Country 1.5inch Wheel Spacers and they have done the trick. They are not meant for HEAVY off-road use, which is fine for me as I would like to make a few more payments before I get too crazy with off-roading. These spacers have their own studs, therefore each wheel has 10 lugs so it is much safer then running with a spacer that keeps the factory studs and loses threads on the factory studs if that makes any sense. Here is a link to the ones that will fit your truck. They say they are made for a CJ, but fit perfectly on our trucks. I have had mine for about 10 months and had NO issues. Hope this helps
http://www.roughcountry.com/wheel-spacers_1097.html
Old 10-16-2012, 12:08 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
To avoid any issues....
make sure the wheels adapters are hub centric and if possible wheel centric, but that can be done via a wheel centric ring.
This will eliminate a lot of variables.
Also, check the torque on the wheel adapter every so often
sales@revelperformance.com
Old 10-16-2012, 07:19 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
i use BORA wheel spacers have had no issue with them they work great and can get them all the way from 1/4"-3.5", i bought them from motor sports tech 225$ delivered for a set of 4 and they are hub centric i did 1.5"
