Old 10-11-2012, 08:48 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Default Weird issue....anyone ever had this happen?
Doesn't matter whether it's low speeds or high speeds when I let off the gas the rear of the truck noticeably moves to the left.
I've checked and double checked the rear suspension bolts. All the link bars are tight. I pulled the adjustable panhard to make sure it wasn't broken. I can't find a single thing wrong back there. It's a 3/5 drop so I thought maybe I was feeling the truck unload and the bar was pulling it to one side but after watching 10 times or so with the mirror pointed at the rear tire I can't see any lateral movement of the axle when it happens.
It feels like it would if the right front brake caliper was hanging but there's no discoloration on the rotor to indicate it's hanging and getting hot. I'm putting new front brakes on tomorrow anyway so that'll eliminate that as a possible cause. If it stops I'll know that was it.
Other than that I'm at a loss....this is the first time I've ever experienced this on any vehicle so I thought I'd put it out there to see if it had happened to anyone else.
Old 10-11-2012, 09:24 PM
audio ram audio ram is offline
Vehicle: 2012 ram sport crew
Trim Level: sport
audio ram is on a distinguished road
If i had to guess i sounds like a thrust alignment problem but it would odd. I would be looking at all the same things you did. Please let us know
Old 10-11-2012, 09:37 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
I measured the rear axle...from the points I used it's true to the frame.
This is a new issue too...I just noticed it for the first time when I drove it earlier this week. It's noticeable enough that when I felt it I pulled over to check...I thought the panhard bar broke.
There's only 2200 miles on the truck...everything is literally brand new. I'll put it on the lift at work tomorrow and double check my measurements in the back. Thrust is a possibility...damned if I can figure out how though.
Old 10-12-2012, 08:32 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
With a 3/5 drop your axle is probably off center roughly 1/2" to 1". I can't remember the geometry of the panhard off the top of my head so don't know which side it will be offset to, but with anything more than a 2" drop in the rear you really should use an adjustable panhard bar to get the axle centered up. I dropped the rear of my truck roughly 1"(slightly less actually) and there's a noticeable offset to the axle. I can't imagine what it'd be like with a 5" drop. I would think this is the issue. With the panhard pushing the axle off center at "resting" height you'd be putting a lot of lateral stress on the 4 links.
Sean
Old 10-12-2012, 11:50 AM
TLSXD's Avatar
TLSXD TLSXD is offline
Vehicle: 2012 Ram 1500
Trim Level: Limited
Rep:17
TLSXD is on a distinguished road
He says in his first post he has an adjustable panhard, probably from Spohn. I would look into brakes a little closer, see if something weird is going on, especially knowing you have checked everything else and it is a new issue.
2012 Ram 1500 4x4
Laramie Limited
GROUND FORCE - SRT 22 - TOYO - SPOHN - HELLWIG - BORLA - ARH HEADERS -RETRO HID - UNDERCOVER - LINE X - BILLET TECH - TRINITY (collecting dust)
Old 10-12-2012, 12:53 PM
snrusnak's Avatar
Rep:1385
OH! my bad.........
Sean
Old 10-12-2012, 05:04 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Guess your gonna have to change your username? J/K, I would also think brakes. Would'nt hurt to to have alignment checked...
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 10-12-2012, 08:04 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
Found it....upper bushing in upper Spohn link bar blown out from contact with the frame.
Swapped in oem link bars today and taller bump stops....problem solved.
Old 10-13-2012, 02:04 PM
Trim Level: sport
that would do it, we were one the right path with thrust line problems
Old 10-13-2012, 08:50 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
Yep...I sure didn't expect that though.
Couldn't see it till I pulled the link bars out then it was clear as day.
