Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 10-12-2012, 07:55 AM
BallSack BallSack is offline
Vehicle: 1995 Dodge Ram 1500
BallSack is on a distinguished road
Default Headlight problems
I am new to the forum I have a 95 Dodge Ram 1500 5.2 the problem is the driver side headlight is dim and when I go from high to low beam the high beam indicator light stays on and the road lights will not work with the head lights on but work fine just with the park lights! And also when the lights are completely off I can flash the high beams normally using the dimmer switch. Have tried 2 set of bulbs .
Old 10-12-2012, 08:11 AM
Resident Technician
Rep:1915
Sounds like a bad ground on the drivers side.
Old 10-12-2012, 08:48 AM
Any idea where the ground would be ? Thanks for the reply !
Old 10-13-2012, 10:37 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
No idea, your going to have to trace it.
Old 11-15-2012, 02:43 AM
Ram Tough's Avatar
Ram Tough Ram Tough is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Color: Primer Gray
Ram Tough is on a distinguished road
I have a 1999 Ram 1500 Sport 4x4 5.2l
Sounds like the problem I had with my head lights my drivers side low beam was very dim and high beam indicator light stayed on also. I traced my problem to a fuse in the Power Distribution Box under the hood... there's two fuses in the PDB one for drivers head light the other for pass......drivers side fuse was blown replaced it everything works great
Old 02-10-2013, 11:38 AM
dongrey dongrey is offline
Vehicle: 2001 Dodge Ram
Trim Level: XLT
dongrey is on a distinguished road
Default Dim Right Headlight
Replacing the fuse did the trick. Thank you. Don
Old 02-10-2013, 05:03 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Glad you got it fixed if you ever have any other questions feel free to post them up
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 10-28-2016, 01:43 AM
DA DODGE DUDE DA DODGE DUDE is offline
Vehicle: Dodge Ram 1500 ST 2006
Color: Blue
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
DA DODGE DUDE is on a distinguished road
I have an issue with my right head light hi beam not coming on. No voltage to the hi beam side. Back probed checking continuity with battery post off , wire is in good shape. Doing research, a lot of Dodge owners having the same issues, either low or hi beam lights went out due to a defective Main control module$$$$ according to YouTube videos.
I am wondering if I can use the left hi out put wire going to the left head light as a input feed to a 12 volt relay to control both hi beams through a fuse to control the hi beams. Or use 2 separate relays and fuses for each head light. I am sure there would be a lower amp draw to energize the inner coil switch.
Or maybe connect to the output wire from the auto dim module?
Any suggestions on the above? I have a hard time finding the correct wiring diagram for my 2006 Dodge Ram 1500 ST 3.7L truck.
I did see a diagram that indicates a RD/OR wire for hi beam out put coming from the MFS. Hope I can find info on this possible by pass instead of spending $$$$ on a new main control module.
Old 12-05-2016, 07:08 PM
Justus8888 Justus8888 is offline
Vehicle: 2000 Dodge Ram 1500
Justus8888 is on a distinguished road
Im think i am having the same problem with both lights. I replaced both bulbs with some expensive ones and now the high beam indicator is always on. And what i think are the high beams are extremely dim. I pulled both fuses and reseat them one at a time. Nothing changed
