Old 10-12-2012, 10:05 PM
ramrod83's Avatar
ramrod83 ramrod83 is offline
Color: Inferno Red
ramrod83 is on a distinguished road
Default another dumb lift question(body/suspension)
what will be easier and cheaper to do..to enable me to put 35s on my 2010 ram.....body or suspension
Old 10-12-2012, 10:09 PM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
Cheapest way to fit 35s is HBS levelling kit, lol $80 !
but between those 2, body lift is cheaper for sure.
Old 10-12-2012, 11:44 PM
ramrod83's Avatar
Color: Inferno Red
so all i need is a 2.5" leveling kit to put 35s
Old 10-13-2012, 07:02 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
this would be currect i would do it with billstiens and a rear coil spacer though, it cost a little more but if you decide to do a real lift down the road those parts can be reused saving you some cash then, where as if you do a level kit, most of the time you can not reuse them when doing a lift just my two since.
Old 10-13-2012, 11:21 AM
ramrod83's Avatar
Color: Inferno Red
so i need the bilisteins 5100 series and rear coil spacers....and what else?
Old 10-13-2012, 01:50 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I ur just doing a level kit for now that would be all u need id do a 1/2 to 1" spacer in the back if your doing a full blown lift that's a whole other story
Old 10-13-2012, 10:18 PM
ramrod83's Avatar
Color: Inferno Red
thanks man...still torn on what imma do i might just go big...lol
Old 10-14-2012, 01:47 AM
Rep:1797
If you're simply leveling, you do not need the rear coil spacer otherwise that will defeat the entire purpose of leveling.
Simply get the hell bent steel or the Bilstein 5100 (which I recommend) and set them at either 2.1 or 2.8 depending on how much rake you still want.
But the rear coil spacer at this time is NOT needed
Old 10-14-2012, 01:49 AM
Rep:1797
What exactly do you want to do?
Another option is the RCX 3.75" lift which consist of a 2" spacer and 1.25" body lift. It's the cheapest 4" lift and this surely clears the 35's
But again, what do you want to do?
Old 10-14-2012, 08:45 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
DO IT lol, if ya need any help just ask, there are many experienced members here, ill help ya as much as i can. fastNugly is pretty knowledgeable also, and there are many others just cant think of usernames right now, to early for me on a day off and im a bit scattered minded still this morning.
