Axle shaft wont seat properly - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-13-2012, 02:31 PM
mike2me mike2me is offline
Vehicle: 1997 Dodge Ram 1500 4wd 5.2L
mike2me is on a distinguished road
Default Axle shaft wont seat properly
I am having some trouble putting my front driver side axle shaft back in. I took out and replaced the passenger side with no trouble but the driver side shaft wont go back into the axle fully it stops about 3 inches short of where it should sit. My only guess is that 4wd was engaged and something (if you look directly into the axle you can see a small piece of metal about 1/2 in diameter)(PICTURE) in the diff is pushing out and preventing me from getting the splines to even get back in to where they should be. The pic is of how far i can get the axle shaft in.
unless anyone knows how to remedy the situation im going to break open the diff cover and take out the carrier to see what is going on but hopefully someone already knows what is going on and can save me the trouble
I have looked all over the forum for this problem and have had no luck finding anything sorry if this is a repost
Thanks
Old 10-13-2012, 11:54 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
If this is the same unit or measured at the same length as the previous unit, you simply have a spline mating problem. the axle disconnect is associated with the pass side axle, sort of... I would try to elevate the inner end with a wedge of some sort, via the axle joint access. Splines can be a real bear to line up, if they're in good condition. I take it that the splines are not aligning. The right side has an 'alignment ball' that helps center the outer axle to the inner coupling, I can't remember having any trouble getting the axle in, once the splines match up, on the drivers side.
Old 10-13-2012, 11:57 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I don't know what to suggest. It's been awhile but I do not recall there being anything special. From what I recall, the axle should just slide in. At 3", it's almost as though it's getting caught on the seal.
At least this thread got a bump.
brad
Interested in one of my mods?
Old 10-14-2012, 01:25 AM
Thanks for the ideas but after i pulled the diff cover i found i had something stuck in the diff where the splines should mate. truck is running properly and on the plus side the diff fluid is now fresh
