Old 10-15-2012, 10:31 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default 2013 air suspension
Has anyone tried a new 2013 Ram yet with the air suspension system option advertised to lower the body height by 2 inches upon ignition shut off? This would make entry/exit and loading so much nicer. I understand that normal vehicle height is restored automatically when the engine is started and it will also again lower the height at highway speeds automatically for less wind resistance and better gas mileage. Further, it's claimed to have a lockout so that normal body height is always maintained until turned off.
I'd be very interested in test driving a Ram with this option and could possibly be persuaded to trade my 2011 if not too expensive.
Old 10-15-2012, 02:12 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Cost
Its a $1,500 option.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 10-15-2012, 02:18 PM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
junk. just another thing to break when the warranty runs up
just my opinion
Old 10-15-2012, 02:49 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
I myself am waiting to test drive the new 13 with this option. As soon as I can get my hands on one I'll post my review.
Big Red my old 2011 Sport
Old 10-15-2012, 03:40 PM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
It's one of the features that has me looking to get a '13 Ram. I need to wait for some other late availability options (Hemi/8 spd and Crew/6' 4" bed), so will have time to absorb reports from early adopters. Looking forward to what they have to say.
I'm personally much more interested in the self leveling and offroad height increasing options than the lowering though - don't really care about that at all, myself. Really want to know how the ride quality is effected by the leveling and offroad setting. I bet the ride is pretty bad with the springs pumped up via the offroad option, but will just have to wait and find out I guess.
- DAA
Old 10-15-2012, 03:50 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
As said above the four corner air suspension is a $1595 added option. I don't know if it will automatically lower at ignition off but I would guessing this is an option in the evic you can change. I do know that you will have a button on your key fob that will allow you to lower it for easier entry/exit in to the cab or the bed.
I am keeping my eye out as well for a fully loaded Laramie to show up at my dealer here soon to test drive. I personally, if I was going to buy, will be waiting for the Hemi/8 Speed combination.
Chrome... in moderation.
Old 10-15-2012, 05:40 PM
BobL BobL is offline
Vehicle: 2013 Dodge Ram 1500
Color: Gray
BobL is on a distinguished road
Mine should be here within the next two weeks and it has the air suspension option. Am curious what happens when I replace the stock tires with something a little (not much) taller and how the system will sense the adjustments.
I think I read that the "park" mode was not automatic and operated via the key fob. Here is more info from the all par web site:
The 2013 Ram 1500 has an optional air suspension system which optimizes ride and aerodynamics, while adding load-leveling. Air pressure increases until the vehicle reaches normal ride height, leveling the truck and improving the loaded ride. It has five height settings that operate automatically or via console or key fob controls:
  • Normal Ride Height (NRH): 8.7 inches of clearance (from the base of the door sill) is the default, load-leveled ride height
  • Aero: Lowers the Ram by 1.1 inches, increasing gas mileage by up to 1%. It is activated by speed.
  • Off-road 1 and 2: Lifts the vehicle 1.2 and 2 inches, respectively, to clear obstacles
  • Park: Lowers the truck by 2 inches from NRH for easy entry/exit and cargo loading
source = http://www.allpar.com/model/ram/2013-ram.html
Old 10-15-2012, 06:31 PM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
I'm going to opt for the air suspension too. It's a little risky being the first in line but the system has been in use in the Jeep Wranglers and hopefully all the teething problems with the new tech are worked out. I might get the extended warranty though.
Old 10-16-2012, 09:06 AM
DAA DAA is offline
Rep:352
Originally Posted by Ford Apostate View Post
... but the system has been in use in the Jeep Wranglers...
It has? That is news to me.
- DAA
Old 10-16-2012, 09:19 AM
gusman's Avatar
Rep:47
Just had a thought... how do they account for alignment when the suspension changes height? Do they not? Which would = rapid tire wear? Cause the norm is any time you do a level kit in a regular IFS pickup, you have to immediately get an alignment to correct your toe in to compensate for the distance between the steering knuckle and rack being greater but the tie rod being the same length... Its just a thought but Im interested in how they account for this
