Old 10-15-2012, 10:33 PM
fishwater fishwater is offline
Vehicle: 2013 Sport QC Maximum Steel
Color: Maximum Steel
fishwater is on a distinguished road
Default Can I tow 8600lbs with 3.55's?
I am interested in purchasing a 31ft travel trailer with a dry weight of 7465lbs. I figure loaded & ready to camp there will be an additional 1200lbs tops. The ram builder sheet shows a max trailer weight of 8400lbs for my 2010 hemi crew cab 4x4 with 3.55's. I will have a WDH with sway control, electric brake control, air bags & LT tires. I know I may be about 200lbs overloaded but will this still be safe? I tow the camper about 8 times a summer for no more than 100 miles at a time. How will the truck do? Any long term damage or safety concerns? I don't see how being this close can hurt but I know I am maxing the truck out for sure.
Old 10-15-2012, 10:45 PM
Zedison's Avatar
Zedison Zedison is offline
Vehicle: 2012 dodge ram r/t
Trim Level: R/t
Rep:14
Zedison is on a distinguished road
I would think it would handle it fine but you may wanna look into some airlift helper bags for the rear they do have a lot of sag compared to the older leaf spring rear suspensions with that it should keep you in the clear and keep you from riding on just bump stops which wpuld make it uncomfortable to drive
2/4belltech drop,mufflex muffler delete,debadged,front,rear sway bars,adjustable trac bar,5%tint,87mm moes throttle body trinity with hemifever tune afe stage 2 cold air and long tubes on the bottle with 6.1 intake on the way
Old 10-16-2012, 08:27 PM
cjm cjm is offline
Vehicle: 2012 1500
Trim Level: Big Horn Loaded
cjm is on a distinguished road
I tow about the same weight, with the same truck. Towed over 10k miles this summer, over mountains numerous times... tows like a charm !!!
Old 10-17-2012, 07:23 AM
So are you worried about the long term affects on your truck for towing that much that often? I know the truck will do it but I don't want to be maxed out all the time, I think we are going to have to get a different camper unfortunately.
Old 10-17-2012, 08:47 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
I would get a set of helper bags and be done with it. I do not tow at all but the RAM looks horrible when towing anything(due to the extreme amount of sag in the rear). I can just imagine how bouncy it is with that much sag.
Old 10-17-2012, 08:24 PM
cjm cjm is offline
Vehicle: 2012 1500
I have Timbrens on the back, and will probably switch to bags... I'm not happy with the effect the timbrens have on ride unloaded. I'm not concerned about affecting the long term health of the truck, the oil, engine and trans temps are consistently stable, and normal, even in the heat of Calif. Although the 3.55's probably effect the off the line performance, I have no complaint about it, and wouldn't need better.
Keep an eye on the gauges as your towing, drive it like you own it and it will treat you well.
Old 10-17-2012, 08:39 PM
Rep:2657
your Ram
Max Payload in the Ram 1,455 lbs
Max Tow 8,500 lbs
Ram website
http://www.ramtrucks.com/en/towing_payload/2010/
other sites
http://www.google.com/#hl=en&sclient...w=1280&bih=687
