Old 10-16-2012, 12:24 AM
sself510 sself510 is offline
Vehicle: 2009 Dodge Ram 1500 Sport
sself510 is on a distinguished road
Default Aftermarket Torque Converter Issue
I installed a circle d TC with a 3000-3200 stall. Once installed, I noticed an immediate issue off the line with the new converter. when I tried to power brake it and bring it up to the new stall, the RPM's stopped at 2500 and would bounce at 2500 give or take a 100 RPM's, never reaching the higher stall, or having the feeling of the vehicle attempting to spin the tires or move forward. Then I also tried a WOT take off from a dead stop, needless to say that didnt work either. It once again jumped up to 2500 RPM's and would bounce the RPM'S slightly moving the vehicle, and once I reached 5-10 mph it would jump to the new stall and take off like it was supposed to. I can part throttle it from a stop and once I exceed 5-10 mph I can then WOT it without experiencing any problems, but only doing it that way will bypass the issue. I havent been able to figure out the problem, and cannot find anyone else experiencing the issue.
I contacted circle d and was told it wasnt the TC it was in their opinion a fail safe in the computer not liking to amount of slip happening with the new TC. But they didnt know what I could do to fix the issue, and only heard of this problem one other time, but didnt know what was done to fix the issue.
So being very upset and not knowing what to do about the problem, I reinstalled the factory TC and do not experience any issues.
If anyone can help me figure out what is going on i would greatly appreciate it, I am open to any suggestions except tearing into the transmission.
Old 10-16-2012, 06:55 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Sounds like you had traction control still on.
That will do it every time.
I cant believe you installed it,then changed it back out again for the Piece of shit stock converter.
I assume you reset your adaptives also.????
My Cirle-D stall works flawlessly,wish i had seen your post earlier,maye could have helped.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 10-17-2012, 12:07 AM
No, it's not traction control I had it completely off using my programmer, and even had it dyno tuned to try and get rid of the issue, but they didn't know what to do about it either.
Old 10-17-2012, 01:21 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
I haven't heard of anyone else having problems with stall converter in our trucks. That's an odd issue. Did you do the install yourself?
If you go WOT from a dead stop what happens? It should rev to 3k or so then take off like a scalded ape.
Old 10-17-2012, 01:49 PM
Yes I installed it myself, checked my clearance to make sure I didn't need any spacers, and put it back together. Everything installed nice and easy like it was supposed to.
After install, I waited about 50 miles until I ran a WOT test. From a dead stop at WOT it will only jump to 2500 rpms, then like the computer or something is holding it back, it hesitates for 1-2 sec, the jumps to the correct stall and takes off.
Old 10-17-2012, 03:44 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It's likely the computer programming. For kicks, tune the truck to stock and try it again, see if the diablo tune is effecting it.
No issues with my 2010 4.7L with a ~2700rpm stall.
BE CAREFUL power braking it, the trans gets hot FAST.
Sean
Old 10-17-2012, 06:51 PM
I have tried the stock tune, and I also disconnected my battery let it sit over night, and reconnected it to reset the computer to relearn the new converter, but the problem still existed.
Old 10-17-2012, 09:47 PM
I didn't get the line booster with my TC. Does anyone think that could help my issue?
Old 10-17-2012, 10:18 PM
snrusnak's Avatar
Rep:1385
I've heard nearly all bad about those. If you see how they work they really can't help.
And I don't have one on mine and it operates fine.
Sean
Old 10-17-2012, 10:37 PM
bighemi04's Avatar
Rep:623
wish I could help, i think you need the transengineer
