Old 10-16-2012, 02:36 PM
texasranger texasranger is offline
Vehicle: 2002 Dodge Ram 1500 Quad Cab
Color: Steel Blue
texasranger is on a distinguished road
Default Headlight Wiring
I've got an 02 1500 and I'm trying to wire my fog lights into my headlights. Can someone point me towards a wiring diagram so I can know which wire is which on the headlight? I need to find the power wire so that the fog lights don't only come on with the low beams or high beams. I want them on at all times that the headlights are on.
Old 10-16-2012, 02:44 PM
99gp's Avatar
99gp 99gp is offline
Trim Level: SLT Sport
Rep:155
I am unsure of the wiring, but i know I was thinking of doing this mod on my 03 to be able to turn my fogs on with highs also. I was looking at brite box. A little pricey but I think it is the correct way to do this mod
Old 10-16-2012, 02:50 PM
99gp's Avatar
Rep:155
Here is also a write up on it with that brite box http://www.ramforumz.com/showthread.php?t=101613
Old 10-16-2012, 02:58 PM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
if im not mistaken the 2002 use a 9007 bulb? there should be 3 prongs, one way to check is with a test light, remove one bulb from the harness. ground out your test light, and make conection with one prong, have someone actuate the hi beams, if test light comes on this is your highbeam, tap into that wire (keep trying prongs till you find the right one. if you want constant power, find the prong that that lights up the test light all the time. which would be a main power wire . then tap that wire, your fogs would be on all the time when your headlight switch is on
i guess a second way would be running a switch inside the cab, and a wireing harness directly to the battery, this way you can toggle your fog lights when ever you like.
hope this helps out a bit!
Old 10-20-2012, 02:51 PM
Color: Steel Blue
Thanks for the help. I think I'm just going to end up wiring the fog lights into my low beams. Thanks guys!
