Old 10-25-2012, 09:57 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
fat frank; I think it's because HULK wants to "SMASH"! Hahaha! To each his own and if you work hard, by all means go and play hard.
Old 10-25-2012, 02:44 PM
HULK's Avatar
HULK HULK is offline
Vehicle: 2007 Dodge 4X4 (HULK SMASH)
Trim Level: SLT Lone Star 4x4
Color: Gun Metal Grey
HULK is on a distinguished road
Originally Posted by fat frank View Post
Sorry, but have to ask. I see these jacked up trucks and some of them simply look rediculous. You need a 12 foot ladder to get in some of them.lol
Seriously, what is the benefit of the super high lifts. Seems like if your axles stick, you're stuck. I don't care how high up you're sitting. What is practical. You need good ground clearance and you can get that with wheels and tires. Again, what benefit do you get with the big lift and body lifts. Of couse, if you drive across a lake I could see a purpose.
I'ld like to hear a reply to this if some of you will and don't get angry. I'm an old man. If I was younger, I'ld probably jack my truck up too.lol
And what about side hills? Aren't you afraid of turning these things over?
While at the 4x4 shop getting my leveling kit installed (old man lift) I saw some wild looking trucks. They had to have spent a ton of money on all of the upgraded suspensions I was looking at. Their shocks probably cost as much as my whole job including alignment.
Later and have a great day
Yea after thinking about this whole thing about getting a huge lift, its just not practical to go super big. Im guna have my truck for a while and dont really want my gas milage to tank on me if I did go big. Im thinking now that a leveling kit will just do the job and the other big lifts are for ppl with the real dough. Also some of these lift kits should prolly just go on a 2500 and up because you still get good gas milage.
just my 2 cents
2.8 level, Train horn, bed cover, headlight brows, blackout grill fins, side steps, reverse work lights, Cameo neoprene seat covers, catchalls, onboard air system.
Old 10-25-2012, 09:18 PM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
Beware, I raise the same question all the time and people freak out. lol
Old 10-25-2012, 10:48 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Hey fat frank; the amount of lift required is proportional to the size of tire desired. The higher you go, the bigger the tire you can run. The bigger the tire, the more stuff you can......get stuck in.
More often then not, this is done for looks instead of real performance. Although there are some limited urban off road benefits, the primary benefit is purely looks and most humans are suckers for looks in some thing or another.
I know a lot of people with lifted trucks, and they all have some idiosyncrasy to contend with but are not willing to give up the "Wow! Nice Truck" for a trouble free truck. IMO, what they (lifted truck owners) have done is not much different then me debadging mine and tinting the tails. I did not accomplish a single thing beyond looks, but I have retained the OEM reliability/functionality (for what it's worth) and spent a lot less. However, when I park next to the lifted trucks, they get the big Ohhh's and Awww's and mine receives the 'also showed' recognition. LOL
At the end of the day it is all about what 'you' like and what makes 'you' happy. All the rest of us just don't matter in that equation.
brad
Interested in one of my mods?
Old 10-27-2012, 12:52 PM
Vehicle: N/A
Rep:1045
once again Brad, you've summed it up extremely well.
in all honesty its just that, looks. there are the select few who build a truck and lift it to just off road it. those are the guys that also swap axles and arent running your basic lift kit. but in all reality most are just for an image.
my last ram had a 5 inch lift and majority of the time it had 35s. that setup got me through most anything here in SD and the black hills. I wanted to go bigger, but that would have just been for my ego, as the above setup did exactly what I needed.
Old 10-27-2012, 02:12 PM
SnoylCC5's Avatar
SnoylCC5 SnoylCC5 is offline
Vehicle: 2007 Dodge Ram
Rep:139
Honestly if you have decided that the leveling kit is reasonable but you still do want something else, look into a 3" body lift. it gives it the looks of a big expensive suspension lift but can be obtained for less that $400. Thats the route im probably going to go simply bc i dont feel like spending $2000 on a lift but still want to sit a little higher than my leveling kit. Just my 2 cents no matter what, have fun and do what you want.... its your truck and your money
Old 10-27-2012, 02:31 PM
Rep:2640
To me a lift is either done right, 2 to 4 shocks per wheel, big springs, rugged wheels & tires, etc.
or it is just street queen
like buying a 4X4 that will never see anything but dry or slightly moist pavement
this is what you see all over Southern California Metro areas
this is what you see serious Dodge owners doing
Old 10-28-2012, 03:10 AM
Rep:2640
I meant that just jacking them up, with no real stability, makes them not worth a hoot when you get off the pavement
A STREET QUEEN
Yes i do live in El Cajon, a major off road performance town, also where GEAR VENDORS is located, & just up the street, FIBERWERX
Old 10-28-2012, 12:10 PM
KR15's Avatar
KR15 KR15 is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: SLT Laramie
KR15 is on a distinguished road
if you arent going out and flexing your truck to death, dont throw out the option of a body lift. its what im doing to my daily driver so i can fit 35"+ tires on it.
good luck whatever you decide
Old 10-28-2012, 04:30 PM
SnoylCC5's Avatar
Rep:139
exactly. body lifts are the way to go if your not off-roading a ton. it makes the appearance better without the price of the suspension upgrade
