Dodge Ram Decals
Old 10-17-2012, 08:25 AM
Dodgeloyal72 Dodgeloyal72 is offline
Vehicle: 2002 Dodge Ram
Dodgeloyal72 is on a distinguished road
Default No gear halo
Hello fellow Dodge owners. I am new to the forum and have a question for everybody. I own a 2002 ram 4.7 with about 39000 miles and I have lost the halo around the prndl21 indicator. The computer thru a code but I cant remember the code number. Has anyone run across this problem?
Old 10-18-2012, 08:18 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:491
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
So you have absolutely no PRNDL indication at all, ever? Sounds like a cluster issue to me. If the TCM reads an invalid PRNDL code from the transmission range sensor, it should send a request to light up ALL of the boxes ("halos") around ALL of the PRNDL positions.
Does the trans function OK otherwise? If so, I'd suspect some cluster / communication problem.
Old 10-21-2012, 08:02 PM
None whatsoever. The transmission seems to shift fine. I have been driving the truck ever since the mil light came on. The code is no ccd message from the tcm (p1698).
Old 10-22-2012, 08:03 AM
Vehicle: N/A
Rep:491
So you've got a bus communication problem somewhere. The instrument cluster module (MIC) is not getting the signal from the TCM to tell it what to display. Sorry, but that is beyond the scope of my expertise. You likely have a bad wire (or connection) somewhere in the PCI bus.
