Old 10-18-2012, 03:16 AM
Exxzaust's Avatar
Exxzaust Exxzaust is offline
Vehicle: 2012 Ram 1500
Rep:24
Exxzaust is on a distinguished road
Default Max offset without running fender flares?
Just wondering what offset do I need without running fender flares? -6mm or will -14mm even work?
Dont be scared of the dark! Shine some light on it
Old 10-18-2012, 03:33 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
How wide is the wheel?
A -6 on a 10" wide wheel will stick out further than a -14 on an 8.5" wide wheel by 11mm (almost 1/2 an inch). Stock is -18mm x 9" wide so measure out how far you want the wheel to sit then calculate from there.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 10-23-2012, 02:02 AM
Exxzaust's Avatar
Rep:24
So i cant find any that would stick out! Everyone I find is 9 inches or smaller with a smaller offset then -18
Old 10-23-2012, 05:14 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
By smaller offset do you mean a lower number like +12 or -6 or do you mean less offset such as +25 or +38?
Old 10-24-2012, 01:25 AM
Exxzaust's Avatar
Rep:24
higher offset like +12 or -6, did you mean in the first reply +18?
Old 10-24-2012, 03:45 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
A 9" wide wheel would work. If you went with an offset between +19 and about -6 you wont need fender flares. I ran a -12 on 20x9 without flares and the tires stuck out slightly, but I liked them that way.
And yes I did mean to put +18 (it's actually +19mm, my mistake) in my prior response.
