Old 10-19-2012, 04:51 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Originally Posted by EWC88 View Post
Looks good! How many coats is that? You hand buffing it?
Thanks! I did 3 coats of VHT and 4coats of clear. Yes, they are being hand-buffed.
What is best/proper way of doing VHT? I'm looking at doing it to my tails because I'm buying another pair anyway. I've done it on my car before the truck, I remember that I cleared it and wet sanded it but didn't buff or polish, and it still looked a flat color. I later removed it because I got a little crazy with the coatings and had it so dark I had almost every driver at night tell me they didn't know I was braking as well as a cop. But with my truck I want to do it completely proper.
Everyone has their own little way of doing it with very similar results. This is what I did:
Wet sanded (using water and dish soap) the covers w/ 2000 grit,then wiped down thoroughly w/ alchohol, sprayed 1 light coat of VHT, then 2 additional light coats, waiting 10 min. between coats. Let covers dry for 24 hrs., then wet sanded again using same method, wiped down w/ alcohol, sprayed 4 coats of clear using same method as VHT. Let dry for 24 hrs., then I LIGHTLY wet sanded again, starting with 2000 grit, followed by 2500 grit. Then I buffed out starting w/ Meguiar's rubbing compound, followed by polishing compound (tip on compounds, don't buff until they start to dry), and wiped off compound residue with clean microfiber towel. Finally, I spritzed them with h2o in spray bottle, and buffed them w/ a white cotton t-shirt. Came out looking like glass! (3rd did, still working on tails actually). Some people skip the sanding of the basecoat, and don't give the covers a full 24 to dry. It looks okay, but I think it's worth the extra effort and patience to have them come out perfect! Just make sure your work area is clean and free of dust/dirt/bugs, and take your time! Let me know if you have any more questions, good luck!
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 10-20-2012, 01:39 AM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
The proper way of using VHT is to only use it on an offroad only vehicle. It even says on the can.
"VHT Nite-Shades™ is a transparent black tail light lens coating for creating a custom European styling. When applied to tail lights, fog lights or turn indicators, VHT Nite-Shades™ appears black until they are lit, then the natural red color appears. Warning: Once applied to a plastic lens, VHT Nite-Shades™ cannot be satisfactorily removed. For off-road use only."
It says that to cover their ass if you get in an accident due to illegal tail lights.
Old 10-20-2012, 06:00 AM
RAM EM's Avatar
Color: Grey
Rep:195
Uh-oh, the tail light police just showed up!
Old 10-20-2012, 06:12 AM
RAM EM's Avatar
Color: Grey
Rep:195
Let me guess, you follow EVERY traffic law, including not exceeding the posted speed limits. Doubtful. I find it ironic that if I tint my tail lights, I'm breaking the law, but most idiots drive around blabbing on their phones the entire time their in their vehicle (which I NEVER do) and run into people/random objects/small children, along with running red lights, ignoring traffic signals, etc,etc. Sigh, where has common sense gone these days?...
Old 10-20-2012, 12:49 PM
Rep:97
You won't find one driver that obeys every single traffic law. A single mental hiccup can results in breaking lesser known laws. One of the simplest ways of keeping yourself out of accidents is making sure you're being seen. These hinder that instead of helping.
Old 10-20-2012, 03:13 PM
SnoylCC5's Avatar
SnoylCC5 SnoylCC5 is offline
Vehicle: 2007 Dodge Ram
Rep:139
RAM EM- your lights are looking good. and if your worried about people being able to tell whether or not your braking, buy a tailgate light bar. they come in handy and are perfect for this exact situation.
mikennrg- even though it says off-road use only, it still changes the way the vehicle looks in a good way, IMO. and is worth doing to your truck to change the look up a bit, providing you dont go too dark bc you are right, it is unsafe, but only if done too dark.
Old 10-20-2012, 04:16 PM
RAM EM's Avatar
Color: Grey
Rep:195
Okay, I've been warned.
I am probably going to add the tailgate light bar just as an added precaution, as well as LED's in the tails. Thanks.
Old 10-20-2012, 06:54 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Man did I cause a conflict? Lol
Question though, I am looking at putting the VHT on all the red parts and keeping the reverse clear, like you did with your third brake light I believe? But I'll do it to tails as well. So if I go that route I'll still sand the reverse area and clear that too? Or no since it's not being touched?
Also you think I should do that with the clear lense for the reverse and third brake like not be VHT with a silver truck? I did that on my old car after modded the taillights to get amber lense out so it was clear and I thought it looked slick.
Old 10-20-2012, 09:51 PM
RAM EM's Avatar
Color: Grey
Rep:195
No prob. Seems like he shows up anytime a "tinted tails" topic is discussed. To keep the clear part clear, I sanded down the entire assembly, then masked off the clear area during the VHT process (using a flashlight to backlight thru the lens helped me see to trim out the lines). Then I carefully removed the tape before VHT was completely dry, and after 24 hr. dry time, proceeded with the clear process. It's up to you if you want to keep the the backup and the cargo lights clear. I chose to tint the entire brake light for aesthetic reasons (I think it looks better all black), and I also realized that utilizing the cargo lights (if need be) when backing up helps quite a bit, so I sacrificed a little output from the backups. Probably going to get brighter LED's for both locations, though. Good luck!
Old 10-20-2012, 10:02 PM
RAM EM's Avatar
Color: Grey
Rep:195
Default Final product!
Here's the end result! Pics don't really do justice, they turned out really well! Just a small amount of red shows thru in direct sunlight. Light transmission from bulbs is still very good, even in daytime!
